horizenjob wrote:
Why would you want the torsional stiffness of a modern hatchback if you car has only one third the mass?
Well, there are two schools of thought on that one. One is that you can't possibly have too much stiffness (subject to weigh limitations).
The other, which I subscribe to, is as I stated above:
"Good chassis design (I would argue) is about stiffness:weight ratio, not absolute stiffness. It's therefore about placing the material you use so that it works hardest for its living, and using only as much of it as you need to
deliver adequate levels of stiffness, whilst minimising structural weight."
The basic rule of thumb for race cars, which I've seen quoted by several well-known designers, seems to be that you need a torsional stiffness of at least 10 times the (road spring and ARB) roll stiffness.
But even on a very lightweight road car, I'd be setting myself a target of 2,500 lb.ft/deg
minimum, whereas many Seven chassis struggle to reach half that.
horizenjob wrote:
...It might start to look different than the Super 7.
Yes, that's a very valid point. If you want to build a Locost that looks like a traditional 'Seven', I think you just have to accept that it's a lousy design - both in terms of structural stiffness and aerodynamics - but that the limitations the design imposes are just part of the character of the vehicle.
Here on this thread, with its topic of carbon fibre construction, though, I'm making the assumption that many people will be interested in more progressive design ideas? Indeed, based on my experience with the design of the chassis I pictured earlier, I'd go so far as to say that the traditional 'Seven' form is heavily sub-optimal, if not outright inappropriate, for a composite monocoque chassis.
