On a practical as opposed to purely theoretical note.
My rough chassis design is basically three boxes and a floor when looked at from front to back.
Two sill boxes and the center tunnel.
Center tunnel can be most any shape I like, thinking angled sides and round top.
I will need to accommodate a shift lever and cable or linkage through the center box.
Side sill boxes flat on the bottom and outside, angle on the inside, flat topped.
Narrow chassis so the inside angles will also form the seat bases.
At the rear bulkhead I can form another box, two if I use a sandwich form at the bulkhead and another angle intersecting the inside sill to form the lower back of the seat.
I really need to learn 3D CAD for illustration, I tend to do a lot of building with no more than a pencil sketch.
Rear will have to take up a sub-frame for the drive-train.
If I go air-cooled engine or rear radiator I will not need to route anything through the sills.
In that case I'm not sure if I should add a round tube, intersecting flat support, or maybe expanding foam?
If I use a water-cooled front radiator engine I may have to route water pipes through the sills so expect that any inside support ends up being round tube.
Intent is to make this light enough that even a lowly Fiat 850 or Sunbeam Imp drive-train would be entertaining and a bike engine alarming.
Original design was VW Bug based, steel tube chassis and fairly heavy fiberglass body, it still went pretty well.
Where this will be most complex is going to be the forward scuttle as I have to put my feet through it and also attach a space frame to hold the front suspension.
No real forward firewall, feet go strait out front as this was essentially a two-place Formula Vee for the street.
My one advantage is that the chassis will be topped by a body that should go a fair ways toward closing the top of the box.
I would bond it on but that would make servicing too difficult.
So it will have to be lots of inserts and screws.
I think I'm going to my PC for a while and try to get my head around the 3D CAD.
