Leggman wrote:
It seems to make sense to use something a bit stronger for the bottom because of the beating it will take from road debris and jacking points.
I guess I don't really see these as significant advantages. How big of road debris will be beating on just the lower frame rails to need the extra impact strength? Personally, I'd be
much more concerned about that same debris of concern hitting the large expanses of significantly weaker unsupported sheet metal floor, than the extremely small percentage of inherently reinforced bottom area that the structural tubes account for. Similarly, jacking points can simply be selectively reinforced hard points. The lower tube intersection nodes of a spaceframe chassis probably don't even need much in the way of reinforcement to make for a good jacking interface point. Regarding reinforcing suspension points, all of the suspension failures that I'm aware of have been the result of the bracket design more than anything else.
But yes, larger tubes can also be used to increase the strength and stiffness of the chassis. More so than increasing tube wall thickness will. Personally though, I'm building my passenger compartment like a tank compared to the engine bay...As I'd rather the engine get crushed in an accident, than me.
