A sealer between the metals is good but does nothing to keep the water out. The individual rivets are dipped in waxoil (that you can make at home) or other sealant that doesn’t quickly setup.
The sides should wrap the edge of the floor. For an alloy floor, I’d seal, add rivets at the ends, then seal on the sides over the top and use rivets through the floor and the side skin overlap versus flush under the side skin overlap. For steel floor, stitched, painted, then seal the side skin overlap over the floors edge.
Horizon, here is a good article on the various hull materials:
https://www.morganscloud.com/2013/08/06 ... o-impacts/Quote: “Mild steel (until it corrodes) can be somewhat less fracture-prone in impacts than marine aluminum, and is also harder to abrade and easier to repair in the field.”
My reverse trike I’m building is using a .050” steel floor and firewall. My GO4s use aluminum sheet, about .080” thick which I have no intention of replacing with steel. I don’t know the alloy they used and it did corrode, allowing the powder coat to flake off in sheets. I used annealed 6061 to modify the floor on the P35 to get more air to the radiator.
Aluminum is a very broad term and all the alloys corrode in one way or another at different rates. Pure aluminum does not, but it isn’t a good structural material. Alclad sheet is an alloy with a thin layer of pure aluminum on top, but it can be scratched through and would be a poor choice for a floor.
In a fire, such as an accident, there is no comparison. Steel will stay solid long after the aluminum is a puddle. Also, in an accident, you do not know if you will be conscious or physically capable of escaping the car. I am not saying everybody should have steel; just sharing some info.
Ford IFS
