It is currently May 22, 2019, 2:41 am
 Post subject: Mill scale on Wishbones
PostPosted: June 25, 2018, 7:26 pm
Should I be removing the mill scale when making my wishbones?
PostPosted: June 25, 2018, 10:26 pm
You should use better steel, that doesn`t have mill scale. DOM is what I used.
Martin
My build log:
My build video:
PostPosted: June 25, 2018, 11:41 pm
Grind, sand, or wire wheel down to bright metal. You'll be OK after that.
The scale can cause bubbles in the weld; not something you want in a suspension weldment.
PostPosted: June 26, 2018, 9:04 pm
For tubing i use a 40grit flap wheel. The scale on plate/sheet is a lot thicker - soaking in vinegar takes the scale right off.
PostPosted: June 26, 2018, 11:26 pm
Apple cider or white... or, does it matter?
PostPosted: June 27, 2018, 6:56 am
Balsamic! We is a class act, y'all! :mrgreen:
PostPosted: June 27, 2018, 9:26 pm
Somehow, I have a little trouble putting "Class act" and "Y'all" in the same sentence, while still keeping a straight face! :wink:
