killernoodle wrote:
The round tubing is all DOM. I'm considering 1 1/4" for the suspension with a .120 wall, I want this car to be solid, even over potholes and stuff. Its going to have 350+ horsepower as well. Is there a need for thick wall tubing on the street? I'm under the impression that 1" .095 wall is pretty flimsy stuff.
So 24' of suspension and 24' of roll bar should be sufficient?
Flimsy? Really? Well you must find it simply horrifying to know that the "book" locost arms are 3/4" x .06" ERW. Lots of those cars have been driving around the UK without failures. (but it seems like I do recall seeing some pics of failures)
I used 1" x .06" DOM and it has hit plenty of potholes and survived so far, noteworthy considering it is 30% thinner walled than what you consider flimsy. I think it all comes down to how good of a job you do designing the arms themselves. Load them properly and you can get by with much thinner tubing. Your 1/8" thick walled A arms will likely bend your frame tubes before deforming should you be unlucky enough to hit something. I'd rather build another pair of A arms than try to fix a bent frame. But to each his own as they say. Everyone has different opinions of what works, that's why you'll never see two homebuilts just exactly alike.
So yeah, you have plenty of tubing. Are you going to just tap that tube and thread the heims into it, being that thick you may have trouble finding "weld in" bungs to fit it. (for a decent sized rod end anyway)
