It is currently May 16, 2021, 2:27 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
PostPosted: March 22, 2010, 4:38 pm
Post 1 of 7
I have seven posts to put here to create a reference topic. Please don't reply to this topic until I have uploaded all seven... so they can be together at the top. Thank you.
PostPosted: March 22, 2010, 4:39 pm
Post 2 of 7
Last edited by SportsCarDesigner on March 22, 2010, 4:49 pm, edited 1 time in total.
Post 3 of 7
PostPosted: March 22, 2010, 4:57 pm
Post 4 of 7
PostPosted: March 22, 2010, 4:59 pm
Post 5 of 7
Last edited by SportsCarDesigner on March 22, 2010, 6:30 pm, edited 1 time in total.
PostPosted: March 22, 2010, 5:00 pm
Post 6 of 7
Sorry this is out of order... it was an afterthought, and I wanted the chart for .065 wall first since it's most common.
Last edited by SportsCarDesigner on March 22, 2010, 7:26 pm, edited 2 times in total.
PostPosted: March 22, 2010, 5:02 pm
Post 7 of 7
TUBING WEIGHT ( lbs./ft.)
PostPosted: April 3, 2010, 8:28 am
Thanks EG :-)
PostPosted: February 16, 2012, 4:21 am
Once again I make use of this terrific information and once again say thanks!
PostPosted: February 26, 2012, 12:08 pm
Very good resource here as well for sizes and weights (page will open with tubes that are most related to us) ..
http://www.coyotesteel.com/products_tubing_round.shtml
PostPosted: February 26, 2012, 3:12 pm
Thanks, SportsCarDesigner and Cheapracer. These are helpful. The .049 chart is particularly revealing. Thinner wall, larger section = less weight, less twist; I knew the concept, but the figures are impressive.
-Pete
PostPosted: March 5, 2012, 2:05 am
Hi SportsCarDesigner, That is great info but I'm so ignorant I'm not sure I fully understand the implications. As I understand it "Torsional" applies to a twisting motion e.g. holding one end of the tube in place while trying to rotate the other end. If that is correct how does torsional strength apply, if at all, to bending force e.g both ends of the tube supported and a weight suspended from the middle? Does higher torsional strenght relate to higher bending resistant? I'm not sure I've even expresssed this in a way that makes sense. :?
SGLTRK
PostPosted: March 5, 2012, 3:07 pm
I use this to compare on occasion ...
http://easycalculation.com/mechanical/d ... -beams.php
PostPosted: March 5, 2012, 8:33 pm
PostPosted: March 6, 2012, 1:29 am
That's ok Raquel Welch.
