John I agree about the engine alignment issue, and that's why I had thought to hard-mount the two engines on a separate frame, making it easier to maintain alignment, and the mouting that engine subassembly in the car frame on isolators of some sort.
I had not looked at the marine splined couplers, didn't even know such things existed, thanks for the info.
turns out though, after an evening of pictorial research, the VW ABA engine may not be suitable for this application, and here's why.
on the VW ABA engine, about .5 crank snout protrudes from the front oil seal.
on the picture shown, that rusty-looking are at the very end of the crank snout is what sticks out of the ABA oil seal flange. behind that red area, the thin dulled line is the mark made by the front oil seal.
in place, with the oil seal flange assembled, it looks like this:
(AEG engine shown, ABA is fundamantally the same)
It so happens, that given the short length of crankshaft engagement, sometimes the timing sprocket can experience a failure and damage the the short key slot. The fix is to drill the crank end for insertion of a dowel pin (sometimes two) thru the sprocket and into the crank snout.
while, by all reports I found, this is an acceptable method of securing the timing sprocket to the crank, its not nearly enough engagement (even if I drill for 3 pins) to make me confident coupling to the ABA crank snout.
So, Plan B... which actually was Plan A when this straight-8 idea started forming in my head.
While I am something of a Volkswagen Man (having owned more Vdubs than any other car make) , I am also a Suzuki Man, having owned more suzuki motorcycles than any other make... it's just the way it has turned out, not any special kind of brand loyalty...
...anyway, as part of another idea - resurrecting my old SuZuki GT750 water buffalo by replacing the worn-out 2-stroke triple with a Suzi 3-banger G10 four stroke - I became familiar with the Suzuki G-series engines and thought the G16 (1598cc four) would make a reasonable candidate, and, again with some pictorial research, so does it seem.
Shown above is the G16 crank snout, which has a nice full length key slot, and engages the timing pulley for much more deeply than the VW ABA or AEG. Further...
...the G16 timing pulley (which is what my coupler will be attaching to - and would have attached to on the ABA) is tapped and threaded for 5 bolts (the VW ABA has only 4)
as can also be seen, the G16 has room around the snout and timing gear for other key slotting, including the press-fit-dowel interface talked about upthread.
the G16 has another advantage over the ABA in that its an all-aluminum engine (the ABA has a cast iron block and ally head). Like the ABA, its well represented in the boneyards so its fairly easy to find good examples of the SOHC 16-valve version. I know I'm losing some displacement and a bit of power, but ultimate power isn't the focus.
swapping to the G16 also solves the issue of connecting to the transmission (I'd thoguht of connecting the ABA to a porsche 944 or 924 transaxle, that would be kinda kewl) but by the simple expedient of using the 5 speed out of a a samurai or Geo tracker, and even including the rear axle from one of those donors, my driveline is pretty much solved - at quite possibly the least expense - with factory parts.
