Has anyone considered or utilized the 2.0L Ford Ecoboost motor in a locost yet?
Here is the link to the engine details:
http://fordperformanceracingparts.com/p ... ield=25303I have seen it for as low as $5,600 including engine, turbo, intercooler, and wiring harness. Also I believe the crate harness unleashes more torque than advertised and as utilized in the Focus ST (They detuned the boost on the low end to reduce torque steer). Here is a dyno graph I found comparing the advertised and stock Focus ST curve vs the curve unleashed by the crate harness.
I did a search and saw some people discussing it a while back but they seemed deterred by price (previously listed as 8K for motor and another 1900 for harness). The price is now at least 4K less and it seems like a more viable option. Still not quite locost, but some people like the idea of a dead reliable and strong engine like an ecoboost, not to mention the motor is new. Also, the dyno graphs seem to show that the turbo is quite small for the motor, which would lead me to believe the lag would be minimal, and there is also headroom for more power later if you should be so inclined.
Questions/Concerns I can think of:
1. It is designed as a front drive motor. Wonder if you would need to modify the oil pan for oil starvation issues or if a dry sump would be necessary to run slicks on track.
2. What transmission to utilize. I believe ford ranger and NC miata transmissions work, but I read that they can't hanndle the torque. Perhaps someone makes bellhousings to adapt it to a T5 or T56 for example.
3. Temperature concerns with turbo motor. From what I have read about the focus st (where engine is from), for track duty and larger intercooler and oil cooler may be helpful in keeping temperatures in check.
Anyway, thought this would be a good spot to revitalize the ecoboost discussion!
