It is currently May 23, 2018, 6:41 pm
PostPosted: June 19, 2016, 9:59 am
OK guys, How much will my performance suffer if I ditch the intercooler on the SR20turbo motor?
Every time I look at the intercooler and plumbing it just pisses me off. I hate the routing, I hate the space it occupies, I hate how it screws up the lines of the car.
So what happens if I ditch the cooler?
Maybe I'll build a second set of plumbing with cooler delete and do some seat of the pants when it's up and running.
Sincerely,
Frustrated in South Carolina
PostPosted: June 19, 2016, 11:09 am
Actually quite a bit. Where you'll suffer the most is hot days &/or repeated runs or longer time on the throttle.
The heat will build detonation will begin & you could lose an engine.
Of course you could just turn the boost way down to build you a little head room or even remove the turbo. :P
It's well worth it to figure out a way to run an intercooler if performance, rather than just bragging rights or having it make cool sounds, is your goal.
PostPosted: June 20, 2016, 7:46 am
I've been asking around on Nissan forums and the general consensus is the cooler is a necessary evil. The knock sensor will keep detuning the engine as heat builds so I don't destroy the engine, but heat soak would be a real problem.
I'm going to spend tom time staring at it after work this week to see if I can do a major re-route
