It is currently May 29, 2020, 12:31 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: January 1, 2017, 1:00 am
My Isetta has a 2006 Suzuki Burgman 400 engine I have recently swapped into it. Everything has went well until... I tried to start it and have a drive. Well, I changed the stator, crank sensor, ecu, rectifier, coil and plug. I have also checked the kickstand switch and brake interlocks with no luck. I think if anyone would have the answer it would be one of you guys. Any help would be appreciated. Thanks in advance
PostPosted: January 1, 2017, 12:42 pm
I forgotbto mention it has lost fire. It will not spark at all.
PostPosted: January 1, 2017, 2:04 pm
Welcome. What a cool project. This would rank very high on my build wish list.
Don't know anything about the Burgman, but you may want to check for a tip over switch. My R1 has one, and it will disable the ignition and fuel pump. It is also possible to inadvertently install it upside down. As me how I know. :ack:
Martin
My build log:
My build video:
PostPosted: January 1, 2017, 3:54 pm
If you can post a wiring diagram for the Ignition circuit, we can probably get it sorted.
Cheers.
PostPosted: January 1, 2017, 6:08 pm
Id the tip over sensor was the case, the starter wouldn't engage would it? And how would I go about testing the tip over sensor? Also here is a wiring diagram. Thanks guys
PostPosted: January 1, 2017, 8:18 pm
Hi,
Cool project indeed. I picked up an Isetta myself about 3 months back. My plan is to restore as original, although hot-rodding has its temptations.
Question, do you have the original engine or trans? I can use parts, even if they are in rough shape.
PostPosted: January 1, 2017, 8:23 pm
What an interesting build! We would all appreciate some more pictures of the car and its new motor and how you installed it. Bill
Bill H
Winnipeg, MB, Canada
PostPosted: January 2, 2017, 12:00 am
Hi guys! Mgamechanic no I didnt get anything but a shell and chassis. No engine, transmission. I jave a few friends that deal with these obscure cars and have access to parts. I've had 5 of these cars in the past and doing this to tbis particular car did not hurt it. I thought it was better than it sitting in a field and rotting lol. And here are are some more pics.
PostPosted: January 2, 2017, 12:04 am
A little dark but after the rear of the frame was straightened and the burgman engine tacked in place
PostPosted: January 2, 2017, 12:05 am
View of the engine from inside before floor pan was replaced
PostPosted: January 2, 2017, 12:08 am
New floor pan
PostPosted: January 2, 2017, 12:10 am
Rebuilt brakes and front axle and wheel spacers dor a little wider tires
PostPosted: January 2, 2017, 12:11 am
A little bit of a look at the chassis with gussets being welded in
PostPosted: January 2, 2017, 12:14 am
Another pic of one of my rebuilt front steering knuckles with all new bearings silentblocs and o rings.
PostPosted: January 2, 2017, 12:17 am
You can kinda see the engine the way it stocks out the back of the cabin.
