It is currently April 19, 2024, 2:01 am
PostPosted: January 26, 2018, 5:56 pm
Looking for a starter ring gear that is 4" to 5" max diameter for a electric revers system. Could be from a electric start ATV,UTV,motorcycle,lawn tractor,or ant thing. Any ideas where to look ?
Thanks, Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 26, 2018, 8:02 pm
Randy,
Martin (mgkluft) used a Ski Doo part:
http://www.locostusa.com/forums/viewtopic.php?f=35&t=14520&start=90
PostPosted: January 26, 2018, 8:15 pm
Thanks, I read that. Wonder what the OD was ?
I maybe looking for a gear that is too small ? 5" or less ?
Trying to get back on the Lotus 11/15 project.
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 26, 2018, 8:59 pm
B85, Try going to a small engine repair shop and see what they've got available in their scrap heap from a Briggs and Stratton or Tecumseh engine that was electric start. You could probably get the matching starter/drive gear for next to nothing too.
Bill H
Winnipeg, MB, Canada
PostPosted: January 26, 2018, 9:24 pm
Going to try that Saturday,good idea.
Was also think UTV,jet ski and the like ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 26, 2018, 9:40 pm
I've spent some time looking into this and the starter motors and ring gears for some small tractors (John Deere, Cub Cadet, etc.) look promising. I think they may be a bit larger in diameter than what you're looking for however.
-Keith
PostPosted: January 26, 2018, 9:43 pm
Found the guy's in the UK, (lynx) now just need to get a reply ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 27, 2018, 12:00 am
Thanks, Rod.
The diameter is about 7 1/4" and it was off a 1976 Skidoo. A purely lucky find off Ebay.
Randy,
I think one of the things to consider is the relationship between the Bendix and the ring gear. Once I found the gear, which was only about $ 40, I did some cross checking, and I found out that the Skidoo Bendix was nearly identical to the SBC starter motor that I found. I can give you some more exact specs if you need them.
From a a practical experience, I think that you will find a small engine gear and starter motor to be under powered. My gear is 7 1/4" in diameter and the starter motor is rated at 3.5 hp, and it takes that much to move the car.
https://www.youtube.com/watch?v=TdObULcKL94&t=3s
Martin
My build log:
My build video:
PostPosted: January 27, 2018, 1:15 am
Martin, your famous I say you on YouTube.
Any all all info would help.PM or post is good. I have been looking at your build and think I can make it fit ? The 7 1/4 is going to be the hard part. Hope I can get something from the guys in the UK but we will see ?
Is you starter a gear reduction ? Also have been thinking about some kind of soft start system ? Here is the space I'm working with.
And thanks for the help and imput.
Randy
American 7 5.0 T5
Lotus 15 ish?
914/H6
PostPosted: January 27, 2018, 1:56 pm
Randy,
this is the starter that I used; it is 3 hp not 3.5, so no burgers for lunch, before backing up.
https://www.ebay.ca/itm/SBC-BBC-CHEVY-3 ... dF&vxp=mtr
The bendix gear is 1.165" OD, and 9 teeth.
Here is a good candidate for a ring gear. Don't know the diameter, but it looks about right. Check with the vendor. The center can be machined off, and a mounting plate made to be sandwiched between the flange and the u-joint.
https://www.ebay.ca/itm/Yamaha-Snowmobi ... Ui&vxp=mtr
I had thought about a soft start, but couldn't find something suitable. Don't know if that would make it more user friendly; it is not the most elegant drive system to begin with, however, it works just fine as it is. My daughters would rather that I don't back up; it sounds too embarrassing, Dad :BH:
I find, that with the roll cage, it is just as easy to push the car back. I only use the reverse when I'm already strapped in or in an emergency.
Martin
My build log:
My build video:
PostPosted: January 28, 2018, 12:13 am
Thanks.
Found a 5 1/2" gear out of the R1 and will see if I can use it ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
