Not sure how that happened. Let me try again.
http://autos.groups.yahoo.com/group/Loc ... sage/41865Engine as in pictures at below link, not including chain and engine
stand.
http://usera.imagecave.com/mconley3/duratec/See some transmission pictures here
http://usera.imagecave.com/mconley3/200 ... nsmission/I pulled most things off and weighed them separately:
engine 192lbs
exhaust (and cat) 20lbs
belt tensioner 26oz
injector rail and injectors 27 oz
power steering pump 120oz
egr valve 13oz
alternator 12lbs
intake (no throttle body and partly broken) 101oz
engine harness (cut at firewall) 45oz
coolant hoses (that I have) 45oz
Some dimensions:
Length from flywheel to front pulley (no flywheel, to end of crank) 19.5"
Width at widest part of block (Where Tranny mounts) 14.5"
Width at widest part of head (At front) 11" (general width) 8.5"
Width including stock manifolds (exhaust not usable) +8" for stock intake.
Height from cam cover to bottom of block (tall side)19" (short side)
18.25"
Note: height of coil on plugs in pictures from above link.
Height overall (from bottom of sump to cam cover) 24"
Length of gearbox from bellhousing to tailshaft 32"
Width of bellhousing 14.5"
Length of bellhousing (at top) 6.5"
Note: see pictures, bell housing tapers to different lengths on sides.
Height of bellhousing 14.25"
Taper of bellhousing Not sure how to get, look at pictues.
Width of gearbox case 8"
Length of gearbox case 10.5"
Height of gearbox case 10.5"
Length of tailshaft 12" (includes 5/6 gear casing)
Weight of gearbox (dry) 101 lbs
Weight of bellhousing (if removable) N/A
