killernoodle wrote:
Keep in mind that most diffs have the pinion low in the case, meaning they are pretty much partially submerged in the diff fluid. Flipping them over puts them well above the fill level and would only be lubricated by any sling off the gears that happens to land behind the pinion and is not slinged off more by the rotating pinion shaft.
Interestingly enough, this is how reverse cut axles are lubricated too. They aren't just a differently cut gearset in the same style housing as a standard axle. Rather they actually use a unique housing that places the pinion
above the axle, due to the way the gears are cut.
And much the way standard cut axles were used in the front of 4x4's for many years, some off-roaders actually use
reverse cut "front" axles in the
rear of their rigs (reverse loading). They do this because the high mounted pinion noticably improves driveshaft angles on lifted trucks. Yes they have to use a somewhat heavier duty axle to achieve equivalent strength to a standard cut rear axle, but they most certainly are doing it.
I know it's not the same exact loading situations being discussed for this method of creating a VW diesel AWD system, but it is probably the most readily available
real world information on the subject. In fact one of the best places to learn more about the
general strength and longevity of both standard and reverse cut R&P's under both normal and reversed loading, might be searching around the "Pirate4x4" forums as they probably know more about it than anybody here...Just some more food for thought.
http://www.pirate4x4.com/forum/
