KB58 wrote:
I'll have to echo what's been said, everything was fine up until you said you wanted really good mileage. You're going to have to structure your priorities because you'll be giving up a fair amount of mileage with the extra hardware in friction, complexity, and weight.
I realize that the extra drive train drag would reduce mileage, however the car as a whole will be lighter than the Golf the engine will be coming from and it got over 40mpg with major engine wear (230,000 miles and a broken ring). It's very common for a diesel Rabbit to get 50+ mpg so I think a locost should get about the same, though the aerodynamics of a brick don't help. The gearing is also better in that configuration than stock for the transaxle so that will reduce engine speed and increase mileage.
However all of this kinda doesn't matter since the primary point of the car isn't fuel mileage, it's performance. I'm combining some parts I already have with some parts that work to make a (hopefully) quick, agile, fun care that is also fuel efficient. Sure I could probably do this with a VR6 and a different transmission, but I don't have them and I don't want to. The diesel is something I already have, is currently getting rebuilt, and provide excellent mileage. I'll be happy with mid 40s city and 50 hwy mpg from this car (driving like a sane person) and mid 30s to 40 on a track. I got just under 40mpg with the 1.6D in naturally asperated form in the 2500lb Golf it has been in (and will go back in when rebuilt), and that was with flogging the thing for 2+ hours till the radiator hose blew. The Golf can get 450 mile with about an 11 gallon tank, and I'm thinking of putting a fuel cell about that size in the locost (probably more like 15 gallons).
On another topic, here's a pic of the wrapped engine wiring:
The big black wire is the glowplugs, there's a ground, 2 oil pressure switches for the stock warning system, 1 oil pressure sender for aftermarket gauge, boost line for aftermarket gauge, 2 coolant sensors (1 is for the glow plug timer), 2 throttle switches, fuel pump shutoff solenoid switch, W terminal lead for upshift light, and alternator wiring.
You can also see at the top the accelerator cable and on the right the cold start timing advance cable.
