Two seven projects for sale. One with V8 Ford power that is nearly complete and one with BMW 4cyl power that is bare frame. Body work, nose cone, fenders, suspension, drive line, 12 brand new hoosiers, etc etc etc. Can email complete details. Price depends on what you want. Will seperate parts. I'll try to list most of the stuff... 6 new hoosier 255/zr14 r3s04 4 on rims 6 new hoosier 225/14 zr 15 r3 so4 4 on rims aluminum radius rods for both cars. rear suspension 4 link with panhard bar 2 electric fuel pumps 2 full auto gauge sets rebco start and run switches 1- wink mirror 1 medium afco race seat umbraco socket head cap screw hardware for both cars remote oil filter adapters both cars rads - front aluminum bmw car, rear aluminum for v8 car, both new wtih electric fans v8 car engine oil cooler. trans cooler v8 -- 350 hp. large valve heads, ported, new valves and springs. large hydraulic cam. flat tops. 5 door road race oil pan, aluminum water pump, all race parts, built by competition engine in winnipeg, weiand xcellerator intake, holley 650 double pumper. moroso acumulator, new bosch electrics including 2 sets plugs, wires, and high power small starter, speedway motors 302 HEI 1 wire ignition. 2 sets wilwood pedals, master cylenders, 1 with clutch pedal 2 battery disconects remote rad fill 2 - 5 gallon fuel cells 1 - 15 gallon fuel cell 1 set new vented and drilled rotors 1 set new rotors 1 set new cast calipers 1 set willwoood aluminum calipers 2 sets new bearings 2 sets hawk brake pads bmw 4 cyl (2l i think) with dual webbers and 4 spd 2 sets roll cage padding quick release steering adapter steering wheel race quality rod ends for all suspension on both cars custom built header on v8 car battery cables aluminum fuel lines chev 10 bolt diffs both cars 1 complete with spool chevette racks both cars s-10 spindles both cars - 1 with 50% steering arms I am not listing lots of the stuff, but it's been a year since I looked at it. Everything has been stored in a heated shop since new.
