It is currently Sun May 26, 2013 12:31 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: Another project part out
PostPosted: Wed May 09, 2012 10:05 pm
Well the time has come to tear it down and part it off. :cry: After a divorce and moving to another smaller house it's time to stop the project and move on to other matters. But, the good news is I've got a lot of great stuff for sale!!
For those of you that may recall I was building a BEC middy that I designed myself. It was a tube frame, 2 seater that used some S2000 pieces and a pushrod suspension. Anyway, Except for the skin, it was built, ran and worked! Yay me! So let's get after it.
* LOCATED IN TORONTO, CANADA *
- 2000 R1 dual headlight assembly with new working bulbs.
- 2000 R1 newer radiator
- Speedo Healer
- Pull-type clutch slave
- 11 gal upright aluminum fuel tank $100
- Flaming River Cobra/MGB manual steering rack (FR1512) $150
- Wheels and tires. It's the buyers responsibility to verify fitment before purchasing. AP1 S2000 fitment $1500
Qty 2, 17x7, 5-114, ET45, Enkei Racing RFP1 Silver, 15lbs ea, P/N: 379-770-6545SP
Qty 2, 205/50R17 Yoko Advan Neova AD07
Qty 2, 17x8, 5-114, ET45, Enkei Racing RFP1 Silver, 16lbs ea, P/N: 379-780-6545SP
Qty 2, 225/45R17 Yoko Advan Neova AD07
I should also have the Enkei center caps around and I'll throw in a set of spline drive nuts.
- Wilwood Forward Mount Brake and Clutch Triple Master with Balance Bar 340-3950 http://www.wilwood.com/Pedals/PedalList.aspx Was $250 new. Used for mock up only. $125
- 1 Sparco Circuit seat with uprights and slider $250
- Set of 2 Schroth Rally road legal belts (roll cage mount)
- Momo Mod 26 290MM steering wheel with Bicknell splined (not hex) QR. $150
- Sheets of aluminum - it's 6061-T6 0.032"... I should have 2, 4'x12' piece and 1, 2'x8' piece. [/color] This stuff isn't cheap... :( But my price is! $300
*** PENDING SALE *** - 2000 R1 engine with new clutch, airbox, fuel pump, gauges, switches and harness (spliced with servicable deutsch automotive connectors $$$)
*** PENDING SALE *** - Hawk Adapter
*** SOLD *** - Tilton 3 Pedal Floor Mount http://www.tiltonracing.com/content.php?page=list2&id=8&m=b
I also have the throttle linkage, right angle bias adjuster and bias adjuster. Was over $900 new.
*** PENDING SALE *** - Wilwood Reverse Mount Brake and Clutch Triple Master with Balance Bar 340-3342
Was $250 new. Used for mock-up only.
*** SOLD *** - 2 Sparco Sprint V seats with uprights and sliders $250 each
*** SOLD *** - Set of 4 Dynamic coil overs from a Shelby Series 1. These are fairly well documented in the forums.
*** SOLD *** - I also have a Rebel Wiring 20 Circuit Rear Mount Wiring Harness Item# RW20-RM. Never used. (Almost for got about that until I read the build log...) :lol:
*** SOLD *** Welding package $500
More to come later as I dismantle and sift through the boxes of stuff I have.
Thanks for looking!
Mike
"There are in fact two things, science and opinion the former begets knowledge, the latter ignorance." ~Hippocrates (460-377 BC)
 Post subject: Re: Another project part out
PostPosted: Wed May 09, 2012 11:03 pm
Sorry to hear you have to part it out Mike.I might be interested in the engine,my needs would be for a cable clutch not hydro,harness to run the engine(no need for lights etc as its for one of my race cars),gauges,the hawk adapter and fuel pump.
Let me know,
Thanks
PostPosted: Thu May 10, 2012 12:29 am
did you sell the frame? do you have a build log?
jim
PostPosted: Thu May 10, 2012 7:49 am
I still have the frame too. My (limited) build log can be found here. I've got some CAD drawings that I did and also some suspension geometry calcs/models in WinGeo.
http://locostusa.com/forums/viewtopic.php?f=36&t=3790
PostPosted: Thu May 10, 2012 11:37 am
if it was built, ran and worked, why break it up? Did it drive?
Jim
PostPosted: Thu May 10, 2012 12:40 pm
Hi Jim,
I think it's less likely to find someone willing to complete my project instead of them wanting the satisfaction of designing and building their own. More builders can benefit from me parting it out than by me trying to sell it as a complete car....just my opinion I suppose...If anyone wants it complete or stages of completeness, I'm open to that as well.
It was driveable. The electrical needed a bit more work to finalize the wiring harness and get it all done up nicely and I had a brake pressure switch installed for the lights that leaked like a sieve. There were a few tack welds that got broken during the last move but nothing serious that can't be easily fixed.
Mike
PostPosted: Thu May 10, 2012 2:14 pm
What would you want total Shipping included (US Mahomet, IL 61853) for the reverse mount MC setup and does it come with the MC's if so what size?
PostPosted: Fri May 11, 2012 10:13 am
Pics!
Second seat available. Not shown since it's in my basement.
File comment: Seat, wheel, clocks, shift lever (cable type push/pull)
File comment: Wheel with QR. Tack welds broke during the move.
File comment: Seat and wheel
File comment: Pedal box. Tilton pedals mounted with masters and throttle linkage. Additional parts come with the pedals (Bias adjuster, 90 adapter for bias adjuster, and honeycomb throttle linkage kit)
File comment: Rack, rad and shock mounts.
File comment: LF suspension. Note: Broken tack welds for bracket on pushrod control arm mount.
File comment: RF Suspension
File comment: As it sits.
PostPosted: Fri May 11, 2012 10:18 am
More pics!
File comment: Fuel tank, fuel pump, etc.
File comment: RR suspension.
File comment: Custom drive shaft
File comment: Muffler, tail lights, etc.
File comment: Custom exhaust
File comment: Speedo Healer
File comment: Rear section overview.
File comment: Serviceable Deutsch connectors for splicing harness with heat shrink and labels under clear heat shrink.
PostPosted: Fri May 11, 2012 10:22 am
Other brake pedal parts.
File comment: Tilton bias adjuster, 90 and honeycomb throttle linkage.
File comment: Wilwood bias adjuster
PostPosted: Fri May 11, 2012 10:25 am
Welder
File comment: Front
File comment: Rear
File comment: Guts with extra tips, drive wheels, etc. MIG wire is almost a full spool, plus a roll of flux core.
File comment: Added bits
File comment: Minor scratches
PostPosted: Fri May 11, 2012 10:28 am
Rebel wiring harness and Appleton steering rack.
File comment: Rebel wiring harness. New in the box!
File comment: Not really clear but each wire is labelled with what its for over the length of the wire.
File comment: Appleton manual rack and pinion. 2.5 lock-to-lock
File comment: Appleton tag
PostPosted: Fri May 11, 2012 12:14 pm
I'm interested in that Appleton steering rack. How much do you want for it?
Fingers of butter and fists of ham.
PostPosted: Fri May 11, 2012 9:42 pm
Hi Mike,
Am interested in some of your parts: The shocks, seats, wiring loom and floor mounted pedals.
I live in Whitby and can come out to see the parts at our mutual convenience.
Please e-mail me at abid at peshimam dot com to continue this further.
Thanks,
Abid
PostPosted: Sun May 13, 2012 12:52 am
Hi Mike,
I am interested in the shock absorbers and wiring harness and depending on the cost/budget the tilton pedals and seats.
Send me an e-mail at abid at peshimam dot com.
Abid
PS: I live in whitby, ON, so not too far away from you.
