I bought a +442E fiberglass scuttle from C.O.L.D. and have decided to go a different direction and therefore would like to see it being used on someone elses project. Scuttle is in good shape with a minor forming imperfection in the front right corner. Shipping at buyers expense, located in Central Alberta, would like $140.00 Cdn for it.
Front, 3.875" diameter hole for steering column. Scratches on front are superficial.
Back, left hole for wiring and right hole is for the steering column.
Left Side:
Right Side:
Bottom, shows notches cut into underside (not visible when installed) to account for steering column support and tubing connecting Tubes Q and P.
Right corner, shows minor damage on front right corner. The paint covers it and its not visible when installed, but there does appear to be a void in the fiberglass.
Picture of it installed on my project.
Its designed to fit the +442E chassis plans and is 320 mm high at the front.
PM or e-mail me at v8_289"at"hotmail.com if your interested or have any questions.
p.s. Shipping to the US will probably make this prohibitively expensive, unless you really like the one piece or style......
