I am getting ready to move and want to sell this engine. this engine was previously in my Locost.
Mopar A4 / W9 racing engine
170 C.I.D.
A4 block with 8.400" deck height & Mopar small block bell-housing on block(not machined away like most midget blocks).
4.135" bore & 3.150" stroke
Forged Mopar Crankshaft
SCAT Rods - 5.7" small block
60 mm roller camshaft
Titanium Valves & Retainers 2.15" / 1.625"
W9 Cylinder head w/ Chapman CNC Ported Chambers
T&D rocker arms 1.6 ratio
Crane Roller tappets
Wiseco Forged Pistons
Compression Ratio 10.0 to 1
3-Stage Barnes Dry Sump Pump & Moroso Oil Pan
Custom fabricated Intake (1/2 of a W9 unit), belt drive distributor & water pump
2 barrel Holley 350 cfm carb
$7,500
Thanks, Jim
jrs7s@yahoo.com comes w/ the following extra stuff:
Motor Plate
Header
Dry Sump Tank
AN Lines for the oil system
AN Lines for the coolant exit from the head
A few extra gaskets
Extra rod & main bearings
Extra Set of Piston Rings
Extra Set of Pushrods
Extra Bearing for Idler Gear on Gear Drive
Extra Valley cover (goes on the edge of the block next to the cylinder head)
Remote Oil Filter Mount and Extra Oil Filter Element
Engine Storage Stand
Extra Camshaft w/ slightly more lift and duration.
