I have had this project on here previously this time I am physically unable to finish the car. For sale is my Haynes Gibbs project as per book except using a Ford Zetec Engine mated to a T-9 five speed.
Frame as per specs except 14 guage on the rear rp tubes (bent professionally) and American sized tubing 25mm-1" and 19mm-3/4". Frame tubes all tig welded suspension brackets mig welded. All the CP plates were fabricated (3mm 1/8") at Kinetic. The suspension A-arms, rear uprights, mushroom inserts, lower ball joints, suspension brackets, bushes and pedal assy. were made by 3G Components in England.
The donor car was a Merkur Scorpio which the front uprights (spindles), differential, brakes (reconditioned) were used. Used the scorpio because of rear disc brakes . There are new drilled rotors, new halfshafts, front and rear pads. New stainless flex brake hoses two new master cylinders with Tilton bias adjustment and steel brakelines already installed.
I was going to use a Ford Zetec ZX3 motor and have bought a steel oil sump from Caternam. The motor I have slipped the belt so it needs to be reconditioned. It is mated to a T-9 5speed trans via a bellhousing adapter from Raceline. The driveshaft is new and balanced . The header was fabricated with a stainless flange and mild steel tubing with a magnaflow muffler.
The steering rack is a shortened new TR7 unit with fabricate aluminum extensions and high angle rod ends. The steering column is a Speedway quick disconnect style.
I have one Kirkey seat with modified sliders . I have made a dash panel and firewall to fit the new fiberglass cowl. The nose and fenders and all fiberglass was made by Curtis. I have fabricated the floors and side panels and rear panel using countersunk rivets and Hysol E-120P adhesive epoxy. Still need some of the interior panels fabbed but have enough 3003 .050 aluminum to finish. Have a pattern made for the front hood.
All of the work has been done by a 40 year experienced car restorer. I have receipts of over $8000 of course hundreds of hours sweat equity. I have a lot more parts not listed that are included. I am asking $4250 for the project. If any questions call Jeff at 816-645-3010
http://s281.photobucket.com/user/miles5 ... t/library/
