It is currently April 20, 2018, 4:53 am
PostPosted: November 4, 2017, 9:15 am
Time to clear out some space in the garage. My Locost 7 project is up for sale.
Based on Caterham 7 SV. Wide body, toyota engine/trans with Miata running gear. have most of the needed parts and a good start. Frame is mounted on a small trailer.
Asking $3000 or BO. Let me know if you are interested. (619)3226529
Located in San Diego
See photos at url=[https://photos.app.goo.gl/afeZxWR3xGtZpwsi1]
List of parts:
Engine/Trans:
Toyota 3SGE JDM 2 Liter naturally aspirated.
Toyota T50 transmission
Bellhousing to adapt Toyota T50 Transmission
Light weight steel flywheel
6 puck sprung hub clutch disc
new pressure plate
ARP flywheel bolts
Hydraulic throw out bearing (Quartermaster 721100)
Ignition module (3SGE HYPERPAK)
Coil and ignition wires (ACCEL)
T50 Drive shaft
Starter
Cooling:
Custom Aluminum 2 pass radiator
Overflow tank (Moroso)
Exhaust:
Silencer
Original exhaust manifold
Header kit with collector, mandrel bends
Electrical:
Headlamp set
Caterham stop/brake lamps
Backup lamp
Dash rocker switches and indicators (Carling)
Push button start switch (OMRON)
Weather Pack harness connectors’
Fuel system:
Jaz fuel tank
Fuel level sender
Vent
Cap with rollover ball
Fuel injection pump and sump
Hard fuel line kit
Fuel AN fittings
Pressure gage
Fuel pressure regulator
Fuel Injection:
Two Mega Squirt fuel injection modules
Fuel injection harness kit
Sensors for injector
Intake manifold with throttle body
Fuel injectors
Fuel injector connectors
K&N intake filter
Brake and Clutch pedal:
Tilton brake/clutch pedal assy
Tilton brake cylinder kits with reservoirs (2ea)
Brake bias bar and adjuster
Clutch master cylinder kit with reservoir
Fiberglass (Yellow):
Nose (Caterham SV)
Front cycle fenders (Caterham SV)
Rear wings (Caterham)
SS rock guard kit (rock guard, piping, pop rivets (Caterham)
Fender welting (piping) (Caterham)
Stearing:
Momo steering wheel
Quick release
U-joints
Ball joints
Woodward Collapsing steering linkage
Suspension:
Miata based rear and front:
Many heim joints and weld fitting
Needs completion
Heater Blower:
Arctic heater/blower
Vent assy
Frame:
Mostly finished:
Cowl fabricated
Needs:
Shocks
Front suspension
Seats
Finishing
Last edited by gottaracenow on November 13, 2017, 3:10 pm, edited 3 times in total.
PostPosted: November 6, 2017, 12:14 pm
This won't last long!
Yaaaaaaay! The profile link is fixed!
PostPosted: November 6, 2017, 4:15 pm
So-Cal is a little broad. Can you narrow it down to a city? I've got friends & family there that might be able to check things out for me. Little easier than driving from MO.
PostPosted: November 6, 2017, 5:26 pm
From the pics and parts list I'm already sold.
Im glad it's far enough away to limit my interest.
PostPosted: November 6, 2017, 7:40 pm
You're probably right!
PostPosted: November 6, 2017, 11:46 pm
Socal is a little broad. I'm in San Diego.
PostPosted: November 7, 2017, 9:20 am
Thanks! Unfortunately all my people are in LA & San Berdoo Counties.
