Been away a lot for work, so progress has been sporadic. I got the juts cut at the base to bump the compression and reduce deck height. was aiming for 0.050" and 9.5:1, got about 0.038" and 10.2:1. Decision was made to roll with it.
The engine went together pretty smoothly, but at one point i forgot a piston circlip, whoops. I had to pull that jug to fix it, but the sealant was still tacky so I put some more and rolled out. The tins fit the more stock width engine way better, but I did have to trim one just a little.
Complete engine ready to be stabbed!
My god dont forget this!
So being a real smart guy, when pulling it the bolts for the mounts were a royal PITA to back up with a wrench, so I tack welded them in. The engine mount has to be clearanced to fit the now fixed in space bolts.
Nothing an cutoff wheel and a dremel cant do.
I got it all back together and started it. The power connections have always been crap, and it was having trouble spinning it over. Yesterday on the way home I also had an epiphany; i never kicked the clutch to center things up. So I loosened all the bolts, kicked the clutch and now it has plenty of ommph. At some point I stripped the hole in the block for the starter too so I had to back it up with a thin nut and through bolt.
Today I got it running better, starting by itself, and the timing set. The carbs need to be rebalanced and the idle tuned, but it runs, revs free, and sounds MEAN. No pinging yet either free revving it hard.
I was hoping to be driving today, but the axles are still giving me hell. the 100mm cv's I got are too thick for the 914 axle. They are EMPI high strength high flex units. (E98-5084-B) They are too thick to put the circlip on. So I need regular units if they are thinner, or maybe a different axle shaft? Suggestions welcome. Good news is the aero CV boots clears the shock even at full droop, something even the 914 setup did not do.
So, I'm very close. Just need to get the axle problem solved for good and I'll be driving again. I could put the old setup in, but seems kinda pointless to undo what I've done so far.
-Brad
