Hi Paul-
Pardon me for butting in...
Tachometers usually have 4 wires. (Usually!)
White is for the light, would connect to the dashboard light circuit
Red is power to the tach itself, would connect to whichever switched "hot" circuit you wish
Black is ground.
Green is the signal input. Goes to the "Tach Terminal" on the ECU, or in standard ignition, to the Negative post on the coil.
Again, usually. Check the manufacturers website, if you can.
JD, father of
Quinn, Son of a...
Build LogQuinn the Slotus:Ford 302 Powered, Mallock-Inspired, Tube Frame, Hillclimb Special "Gonzo and friends: Last night must have been quite a night. Camelot moments, mechanical marvels, Rustoleum launches, flying squirrels, fru-fru tea cuppers, V8 envy, Ensure catch cans -- and it wasn't even a full moon." -- SeattleTom
