Wiring help http://www.locostusa.com/forums/viewtopic.php?f=44&t=13117 |
Page 2 of 2 |
Author: | solder_guy [ December 25, 2011, 4:10 pm ] |
Post subject: | Re: Wiring help |
I zoomed in on the module 01007 and although it looks like it is mislabeled think it does allow for front turn signals .. Rob |
Author: | N. Versailles Cobra [ February 11, 2012, 6:08 pm ] |
Chuck/Rob, Finally got back to my wiring mock-up and looks promising. Have found a bad socket (new) on one side repeater light so need to correct that to get front signal working, but rear turn lights blink with the 3-2 converter & motorcycle module as you suggested. They work with the "brakes on" and/or the running light simulation on. The HAZ's work using both momentary on switches per mfg. inst. Need to get the last of the sheet metal work completed and will be ready for "real" wiring exercise. Thanks for everyones help. Don |
Author: | Ewhen [ February 12, 2012, 9:13 pm ] |
Here my two cents The easiest and surest way for electrical system to operate properly in a hand-built car is to use donor harness ,trimmed to the bone. (Ie. to remove all useless wires ,of which there might be 200 +). Included below is pic of your truly with son, just performing the above noted abortion. Ewhen |
