hassleweed wrote:
Cut, splice, solder, wrap in heat-shrink?
Thanks
Yup, solder is a must. Heat Shrink is the most reliable isolator for the joint. It's a chore! I removed two full paper boxes of wiring from my miata harness. The bulk came from the excess stuff like power windows/retractable headlights etc.
- A tip for you: Don't buy your heat shrink tubing local. Go online to Digikey or somewhere like that. It's 10x the price if you buy from radio shack / lowes etc. I even tried a local electrical supply co. but they were very expensive too. Buy a couple different diameters since you'll be splicing multiple gauges.
I found the hardest part was dealing with splices that went to different places. Cutting 3 feet out of a single wire is easy. It's killer when that wire goes 10 inches then splices off to a relay, then goes 10 more inches and splices off to a switch, then goes 10 more inches and splices off in a 4-way that goes to yet 4- more places!
The only real key is to take your time and only ever cut
one wire at a time. I think I got $20 back from the copper I recycled. - It's the best of both worlds, lighter car and heavier wallet!
(OH, a good factory wiring diagram is an absolute must!) I got one from someone here online. I know i have a hardcopy covered in solder slag and burger grease. I'll see if I can drum up the electronic copy if you need one.
Good luck!
rusty
Miata based, custom chassis build in progress.
First Drive!!! http://locostusa.com/forums/viewtopic.php?f=35&t=2269&start=375
