If the splices are a concern, remove them then solder and heat shrink. Small zip ties are handy if the clips that hold the connectors together are broken. A 100 qty pack of 4 inch long, black, uv protected zips costs about a $1.
No need to remove the starter to test it. Plug a spade terminal wire into the solenoid, then with it out of gear and parking brake set, key off, touch the other end of the wire to the fuse panel feed from the starter.
Many folks don't use the key to engage the starter as a theft deterent. Just a push button some place else.
Wire from Waytek comes only in 250 foot rolls but 250 feet of 14 ga automotive primary wire is only $25, plus shipping.
http://www.waytekwire.com/products/1453/Wire-Cable/BTW, nice build. Love those rear fenders.
Ford IFS
