BBlue wrote:
First up, the clock does not really fit the space, dropping the battery would make a nice installation. Also, the Indiglo was on for maybe a minute during that 15 year time. I want to run the Indiglo whenever the lights are on. So two 1.5v power feeds seemed logical.
Current draw. Now your getting into the vast world of stuff that puts my inadequacies on full display. I don't know what I'm doing and I get lost in all the zeros. The best I can tell you is that with the VOM set on 2000k, the clock resistance is 155 with the light "On". Xero with th elight off.
Battery voltage is currently 1.4. I have tried several tries at voltages. The clock will run as low as .9v. I've tried voltages all the way up to 1.8. Initially I was using a small battery charger and decided that maybe there was some AC leakage screwing things up, so went to car battery as power source. Thinking perhaps the voltage was correct but the amperage was too low, I've varied V1 resistance from 1,000 to 15,000.
Thanks for the interest in my problem. While it may seem I have avoided some questions, I've done the best I can to describe the situation. Your educated guess as to proper resistance values would be very much appreciated.
Bill
you trying to run the clock off the car battery? IF so I would use a LM317 to drop the voltage, or a 20ohm resistor.The LM317 would be a better solution IMO. A couple solder joints and a few components would work.
