It is currently February 22, 2019, 1:58 am
PostPosted: July 17, 2015, 2:47 pm
So there is an option in the gauge cluster to set the RMP signal input. I choose #2 for my 4cyl b16 engine. is that right? My gauge is bouncing and is reading different than my ecu. thoughts?
PostPosted: July 18, 2015, 8:19 am
Unless the gauge rpm is consistently the same multiple of what the ECU is telling you, it probably isn't the programming. The bouncing part sounds to me like you've got a noise issue.
PostPosted: July 18, 2015, 9:19 am
I was thinking the same thing. I will try some shielded wire.
PostPosted: July 18, 2015, 11:16 pm
I have mine set on 2 for my h22 and it is smooth, solid, and reads what I would expect. I am using a shortened honda harness though, so it maintains the factory shielding.
PostPosted: March 27, 2016, 12:06 pm
Not sure if you're still having a jumpy tach but mine turned out to be jumpy as well with the new wire routing I ended up doing. Apparently the KOSO gauges are pretty notorious for being sensitive to noise. I added this filter and it smoothed it out perfectly.
PostPosted: March 27, 2016, 12:43 pm
Yeah I fixed it buy running it directly off the ecu rpm instead of the tach output off the dizzy
