It is currently May 19, 2019, 11:07 am
PostPosted: August 24, 2016, 12:00 pm
I have a race car application with a stand alone ECM & engine harness custom made from Enginewiring.com for my GM Ecotec motor. I have no lights, wipers or anything a street car would have. The wiring guy stripped down the engine harness to cover just what I need to run the motor with the factory ECM. He added a fuel pump relay and fan relay with a single power connection wire coming from the harness. I'm used to separate fuses for everything but this all now runs through the new harness. Is it a simple as it looks with a single fuse for everything? What do you recommend for a fuse block set-up a fuse size?
Link to my build log:
PostPosted: August 24, 2016, 12:19 pm
On mine I did 5 fuses and 4 relays.
Relay for fuel pump, ECU main, run/start/charge/ ECU backup power circuit, and fan
The 5th fuse is 15 amp 12v switched power to the datalogger.
I have 3 open fuses I can wire; 2 battery hot and 1 switched if I want to expand.
PostPosted: August 24, 2016, 12:26 pm
The problem with a single fuse is that some PCM circuits/components will not be properly protected, or may blow fuses. There is a reason PCMs have multiple fuses and, while I am not an electrical engineer, I can only assume it's to separate the big stuff from the little stuff and/or to keep clean power for sensors. Things like injector drivers shouldn't be on the same fuse as things like MAF sensors.
http://www.12voltplanet.co.uk/fuses-guide-uses.html
Cheers.
PostPosted: August 24, 2016, 2:42 pm
Fuses are used to limit the maximum current that can go down a wire to a device. Typically the fuse is sized to protect the wire from overheating and not so much to protect the end device from overheating. If your total draw is 50 amps and you put in a 50 amp fuse, the first time you get a short to ground in any of the little wires that are on that circuit, you are going to release all of the smoke that was installed in that wire at the factory, and probably some of the factory flameage too.
So you CAN use a single 50 amp fuse, but all wires that it feeds power to will have to be 6 guage wire.
Tom
PostPosted: August 24, 2016, 3:10 pm
To be blunt, most people are idiots when it comes to fuses, regularly replacing "bad ones." A fuse blows in order to protect the wires and is an indication that there's something wrong downstream. Replacing it doesn't fix the problem.
PostPosted: August 24, 2016, 10:18 pm
I was in a hurry earlier. At the very least you should have these fused separate from the little sensor wires:
-Injectors
-02 heaters
-MAF
-coils
-? I may be forgetting something.
Is it possible these are fused with inline fuses hidden in the harness somewhere?
If not, I would be inclined to check your PCM wiring diagram and then add fuses to it as per OEM ratings. This still has potential to allow excess current to hit some things, but less likely, and less current than only one fuse. To do it right at this point you need to measure full expected load on each circuit, and then fuse accordingly. I forget how much you are supposed to go up in fuse size from typical load, but I want to say 15-20%(?) is typical. If you post the PCM wiring diagram, we should be able to help further.
Cheers.
