It is currently July 15, 2020, 1:54 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: April 22, 2019, 11:06 am
Hey Roadog7
Thanks for that. I checked my Dolphin manual, the net and the gauge, and no dip switches. I just sent an email to Dolphin.
I note on that you had to set your tac for single pulse, which would indicate that the ignition system adjusts the output from two pulses to one, which would be a normal non DIS system I would think... So...hopefully I will be ok.
It is great to hear that you had good luck with the Ehrlich ignition. They seem great, but adjusting initial timing is clearly a bear. Especially on a crank that is not keyed..... On mine, there is a plate with four bolts that allows the timing marks to move independently of the crank damper.
McSorley designed 2+2 with Zetec, T-5 and Mustang 2 suspension.
PostPosted: May 22, 2019, 3:39 am
Hi All,
I've had quite a few distractions lately but have been meaning to post an update. After exhausting my brain and eliminating as many variables as possible, I ordered the Nodiz setup. Only one issue with one of the leds on the unit not operating, but I got it all mocked up and it fired right up! I still need to wire it in properly and fix a new alternator charging issue, but am very pleased with the setup.
I still don't have any idea as to why the Q4R system failed, but I am very relieved that the Nodiz is truly plug and play. Although the fix was more expensive than I had hoped, I am looking forward to later upgrading the tune to 3D. Thank you all for your valuable input!
-Robert
