oddsaabs wrote:
Wow, thanks for all the suggestions and input. You guys rule.
I really like the idea of removing the roller bearings and pressing in a spherical one. I'll do some dissection tomorrow and see how it goes.
The bellcrank is the stock unit that comes with the Hayabusa shocks and works perfectly to translate the 5" of wheel travel into 2.5" of shock travel. I used these because the stock springs are pretty beefy at 700# which should translate well considering the 2:1 wheel to shock movement ratio.
Botbasher, which bike are those shocks and bellcrank from? They pretty nice.
Sorry for the delay in getting back.. I was stuck in DC for a cooking competition.
Those shocks are from a Yamaha R1 (07 I believe). If you search on eBaste, you can find them as complete assemblies, with center pivot and bearings. They are very versatile, as you supply the out board pivots (I shimed my Rod Ends into it!), so they can be anything you need, rather than trying to make what you have fit.
Take a look at some of the other motorcycle mfg options, maybe you can mix and match. The pivots are very similar through out the different mfg's, so you might find something that'll work!
Cheers!
KS
Check out
Firearm Finishes & Coating for options to ceramic coat your Locost parts. Hundreds of stock or custom colors including Chrome and Clear Coating options now available! High Temp options for hot bits!! Plastics too!!
