It is currently Tue Jun 18, 2013 12:39 am
 Post subject: Miata steering column plate/shim/spacer
PostPosted: Tue Mar 06, 2012 5:43 pm
To the vast population out there that has used the Miata steering column, I'm curious if you installed the column in your car with the sliding plate that is attached with a twist tie. See attached picture if you're not sure what I'm talking about.
After doing some searching on the Miata forums, it seems like that plate is there to slow down the collapsing of the column until the airbag deploys. A lot of Miata guys that replace their steering wheel with an aftermarket non-airbag wheel generally talk about 2 things: 1) removing the tear away stitching in the seatbelt and 2) removing that plate. An added advantage of removal of the plate is that the steering wheel is raised a bit, giving more legroom.
Just curious what you guys thought of it, and if any hasn't used it since our cars don't have airbags. Not really sure it makes a huge difference in our application, but I have to embarassingly admit that I for the life of me cannot find that part in my garage (I should have never taken off the twist tie!!!), and am debating whether to just bolt it up without it, or buy a used column off of ebay for $50 just for that one part. :BH:
 Post subject: Re: Miata steering column plate/shim/spacer
PostPosted: Tue Mar 06, 2012 7:16 pm
Karma has already answered your question...
Steve
PostPosted: Tue Mar 06, 2012 10:01 pm
No, you don't need that part.
