cs3tcr wrote:
Richard, 4 1/4" = 108mm does it not?
Doh!
I know that, at least I do when I'm fully awake.
And once again a product idea dies as it's already being done.
Looking forward to an end to the 14 - 16 hour days I've been doing lately.
The good news on the long hours is that the current CNC job has a twenty minute cycle.
I've been using that time to 2D sketch the build, drive-train, chassis, rear axle and front suspension center-line.
Also laid out my build table with a grid pattern, very handy to see how the changes go when setting seats, trans, and simulated engine in place.
Set the rear body over the axle and I will not have to narrow it after all if I use stock Alfa off-set wheels.
Looking at 205/60-14 tires, might even be able to do 235/60 in the rear if they are available and work with 6" rims.
So far this appears to working out just a little too well to be believed, I know the body was not designed around an Alfa Romeo Spider!
