It is currently April 18, 2024, 11:52 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: January 30, 2019, 4:09 pm
I would be happy to use the obp pedal box. I am just wondering if the master cylinders will be sufficient for the brake and clutch? I am on a 1999 non sport 1.8 model.
FastG wrote:
My car originally had the stock Miata over head pedals. The angles were all wrong and the pedals scrubbed on the sole of your foot as they want thru the arch. Probably because you sit so low in a 7. I swapped to a OBP floor mounted pedal box. I also knew I was going to play around with brakes so I liked the flexibility of having individuate masters. I do have an adjustable bias setup with a remote adjuster. I never installed the remote adjuster I could never work out a good routing for the heavy cable. Plus I do not have the skill to change the bias real time. I have made some adjustments and lets it set.
Graham
Users browsing this forum: fordo and 16 guests
