It is currently July 23, 2019, 7:07 am
 Post subject: Miata Steering Rack
PostPosted: February 18, 2019, 7:52 pm
So I decided to cut the rack down 4.75" and took a few photos of how i did it. not sure why people cut the shaft in half and weld it up when you need only cut off one end and drill and tap.
Well, it wont upload the photos.
So Simply all I did was cut the 4.75 inches off the long end of the shaft, the shaft is completely hollow so the I drilled the hole slightly larger and tapped it with a tap matching the inner tie rod bolt. Then cut the 4.75 inches from the housing center and welded it back. Screwed the ties rods on and DONE!
Not sure the thought of cutting the excess out of the middle of the shaft and then welding it back together and having to then grind it smooth. I'm sure this isn't very safe.
Sorry, no photos.
 Post subject: Re: Miata Steering Rack
PostPosted: February 18, 2019, 7:56 pm
I agree. I cut mine by about six inches and drilled and tapped the end. I've put 28,000 ,miles on it since.
PostPosted: February 18, 2019, 8:58 pm
Same construction on the RX7 rack. No way would I cut and weld the shaft.
PostPosted: February 19, 2019, 12:40 pm
If you can't do it with a phone, pick up a digital camera. Consider it as just another tool for the build. :cheers:
PostPosted: February 19, 2019, 12:45 pm
Uploading from facebook photos.
You will notice the two groves in the shaft.....that is the spot where the center piston was. Groves didn't harm it much but I cleaned the shaft and filled with glass filler and sanded smooth. Added about 15 minutes of extra work but was fine with that. Tap and drill bit cost me an extra $18 but is IMO the only way to do it. Way easier also. Cutting shaft and welding it then grinding it smooth would have taken me much longer. All this I could have done with a cut off wheel but since I had a lather at work my friend cut the shaft for me.
File comment: Finished part (before welding) Used a M16 x 1.0 tap and tapped new threads into the shaft.
File comment: outter tube after cutting and trial fitting. Was very happy with the git. Now onto the tig.
File comment: More bits
File comment: All the bits
File comment: Now to the band saw to cut out 4.75" from the outter tube.
File comment: Piece that was removed. I lathed the new end same as the original and will cut two groves in it with a disc cutter for the locking nut.
File comment: Cut off 4.75 inches
File comment: Cutting the shaft in a lathe. Could easilt use a cutter though.
PostPosted: February 19, 2019, 2:40 pm
no fair! You have friends! With tools!!!
PostPosted: February 19, 2019, 5:28 pm
I like to think of it as having tools....with friends.
PostPosted: February 19, 2019, 5:55 pm
Fantastic detail! Thanks for the update! :cheers: How about doing that for your build topic?
I'm also in ATL, fwiw.
PostPosted: February 19, 2019, 11:24 pm
Hint Hint Wink Wink. :roll:
PostPosted: February 20, 2019, 4:53 pm
Yeah I think I should update my build. Been really busy with kids, work, fishing, hunting, traveling, motorcycling, and too many other things. BUT I am finally going to start working on this project this year. Going to get a rolling chassis in about a month, and hopefully finish it by this time next year. Have only worked on it 2 months a few years ago and then about for about a few weekends this year. I dont plan on working on it during the heat of summer but spring and fall months. I really need to start thinking about how to register it. Thats going to be my hard choice.
