Dave, I'm pretty sure you have that backwards. With lube, one
reduces the torque to get the same stress/clamping force of a dry joint. Here are a couple of references to verify my position.
https://www.engineersedge.com/calculato ... e_calc.htmhttps://www.fastenal.com/en/83/torque-calculatorYour comment "You can typically Re-use Ny-lock nuts ten times" is better stated as "
up to 10 times" A lot of that is dependent on "conditions" of which we have no control over. The temperature during application, how old the nut is, moisture content of the Nylon etc. all have an effect on their reuse. You have that covered with your wording of "typically". The truth is that I have reused nylocks on occasion. I prefer the deformed nuts (Stover nuts) in the Locost suspension.
davew wrote:
You can typically Re-use Ny-lock nuts ten times, unless a high speed electric nut runner is used, which melts the nylon. Adding lube, plating, wax, E-coat, etc., requires that you increase torque. If you have a combination of those, you have to add even more. In a racing vehicle you can add a paint mark on the flat of the nut each time you re-use a Ny-lock nut, then replace it after 6 times.
Davew
