It is currently May 25, 2020, 10:56 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: April 14, 2009, 7:15 pm
Damn. Can't be easy :D
PostPosted: May 9, 2009, 8:24 pm
Subaru
Front - 5x100, 6lbs
05+ Legacy/Outback
08+ Impreza - non STi
09+ Forester
Front - 5x114.3, 6lbs
05+ Impreza - STi only
06+ Tribeca
Rear - 5x100, 7lbs 14oz
00+ Legacy/Outback/BAJA
09+ Forester
Rear - 5x114.3, 7lbs 14oz
06+ Tribeca
08+ Impreza - STi only
PostPosted: May 21, 2009, 9:17 pm
The mid 90s Dodge caravan hubs were a bolt on affair and should be cheap. Bolt pattern is 5x100 See below for other applications:
AM Autoparts Price: $57.70
Year Range: 1991 - 1994
FREE SHIPPING AND HANDLING!
Specifications:
Front Wheel Bearing and Hub Assembly
Fits Driver OR Passenger Side Front
Brand NEW fitting the following years and models:
1991 1992 1993 Dodge Dynasty
1991 1992 1993 Dodge Daytona
1991 1992 1993 1994 Dodge Shadow
1991 1992 1993 1994 1995 Dodge Spirit
1991 1992 1993 1994 1995 Dodge Caravan (With 14 Inch Wheels)
1991 1992 1993 1994 1995 Dodge Grand Caravan (With 14 Inch Wheels)
1991 1992 1993 Chrysler New Yorker Fifth Avenue
1991 1992 1993 Chrysler Imperial
1991 1992 1993 1994 1995 Chrysler Lebaron
1991 1992 1993 1994 1995 Chrysler Town & Country (With 14 Inch Wheels)
1991 1992 1993 1994 Plymouth Sundance
1991 1992 1993 1994 1995 Plymouth Acclaim
1991 1992 1993 1994 1995 Plymouth Voyager (With 14 Inch Wheels)
1991 1992 1993 1994 1995 Plymouth Grand Voyager (With 14 Inch Wheels)
1992 1993 1994 Plymouth Duster
Product #: AM-24006137
PostPosted: May 21, 2009, 9:24 pm
In my opinion this is a notable drawback when it comes to lightweight wheel availablility. I would think it best to try to find 4x100 or 4x114.3/4.5...Or maybe 5x114.3/4.5 too, if you're using wheels larger than 15".
PostPosted: August 7, 2009, 1:07 pm
The Chevy Cobalt base model uses a bolt in hub assembly that looks pretty compact and uses a four lug pattern. 4x108 Cost about $45 a pop.
Also fits:
SATURN ION 2003 Front,
CHEVY COBALT 2005 2006 2007 2008 Front, 4 lug,
PONTIAC PURSUIT 2005 2006 Front, 4 lug,
PONTIAC G5 2007 2008 Front, 4 lug,
SATURN ION 2004 2005 2006 2007 Front, 4 lug,
PostPosted: August 7, 2009, 3:50 pm
Auto Motive, My friends call me Motive
Actually Caravans came with both a 5x100 and a 5x114. Models that came with 14" wheels were the 5x100, 15" or 16" wheels came with the 5x114. It would also be easier to use the rear bolt on hubs as they are preloaded so you wouldn't have to machine the end of a cv axle to use them on the front. Look as my build log and in the resource section for information and drawings of how I used this hub for custom uprights. (Which I'll machine for $150 "shameless plug" :mrgreen: )
I don't think that 5x100 really is a setback as far as wheels go. Both WRXs and most modern VWs used this bolt pattern. Try finding lots for those 4x108s or 4x105? the focus uses. :roll:
Also note how all these hubs bolt on. if the hub is threaded for bolts then it will have a protusion on the inside that needs to fit in a precision machined hole to locate it. If the hub has smooth though holes then it is usually flat on the inside.
My Build Log: viewtopic.php?t=5850
CAD Drawings:http://locostusa.com/forums/viewtopic.php?f=26&t=6376&p=62465#p62465
PostPosted: November 8, 2009, 1:22 am
Lumbering Giant
aero_bro wrote:
Here's a link to an official PDF for Timken bolt on wheel hubs, listing all the applications for many makes and models with part numbers and dimensions for 1990 and newer automotive hubs. Warning though it's a 4.5mb file.
http://www.timken.com/en-us/products/Documents/BSAC1990andNewerOrder7564.pdf
This catalog is gold. Starting on page 487 is a section called 'Hub Unit Bearing / Bearing Module - Numerical Listing' that has enough information to allow you to spot hubs for your bolt pattern and wheel nut size. From the number of splines you can tell if it is for a driven wheel.
I found one that looks pretty likely for my use in Haynes-type uprights. It's HA590240, used in the Mitsubishi Galant (4X114.3). The internal diameter is 1 mm bigger than my axle, but I figure that a driveshaft shop could take care of that. I'll keep looking and make sure that I understand all the dimensions, but it's encouraging.
Dreaming the dream since 2003. Haynes chassis, Miata uprights, everything else from 1987 NA RX7 donor.
PostPosted: November 9, 2009, 8:12 pm
I thought so too. I'm using a LS3 Corvette engine, and since the Vette uses bolt on hubs front and rear that mate to universal uprights, I figured why not just use those. I must admit though that they aren't exactly low-cost. The catalog gives you the exact dimensions for front and/or rear hubs, and the part numbers.
Ken
PostPosted: January 31, 2010, 9:51 pm
Also fits:
I would like to correct this, as I'm on the hunt for bolt-on hubs. The Cobalt is a 4x100 hub. The drive hubs are bolt on, as are the non-drive hubs.
The Toyota MR2 Spyder has Bolt-on Hubs in the front with 4x100. The Prius has a similar rear hub.
PostPosted: February 6, 2010, 2:21 am
Has anyone seen one of these hubs for real?
I'm trying to get my hands on one to see how it would fit a single seater, but there seems to be a bit of variation in the pictures I can find on the web (possibly people are just being lazy and not using the correct picture).
Unfortunately, it looks like the Corolla the Cobalt was based on was never sold here in Australia, so I may have to import some.
PostPosted: February 7, 2010, 7:18 am
The Cobalt was never related to the Corolla... it is built on a pure GM platform (Delta), built in Lordstown, Ohio.
You may be thinking of the NUMMI cars (1985 to 1988 Chevrolet Nova, 1989-2002 Chevrolet/Geo Prizm, Toyota Sprinter, Corolla Seca) built in the Toyota/GM joint venture plant in California. That is one of the two platforms the Cobalt replaced, the Cavalier being the other.
The late 2004 to (April) 2009 Holden Astra is the Australian "Cobalt" (Delta platform). That doesn't always mean ALL the parts are interchangable worldwide, of course.
Cobalt is at the end of it's life, being replaced by the Cruze (GM Delta II platform) later this year.
GO COLTS !!
PostPosted: February 7, 2010, 8:41 am
I must have got confused, looks like it was the Prizm I was thinking of (my expertise on ADM econoboxes is lacking). It matters not, it looks like we've come up with a cheaper, lighter solution anyway.
PostPosted: March 6, 2010, 11:45 am
80's Honda Accord has big vented discs and 5 x 114.3 but the calipers are heavy.
Toyota Camry doesn't as well as a host of other Jap and German cars I am aware of so it pays to check.
PostPosted: June 7, 2010, 5:15 pm
http://www.discountedwheelwarehouse.com/Vehicle_Bolt_Pattern_Reference.cfm
86 BMW 325 coupe powered by Ford. http://www.e30v8.com
PostPosted: August 13, 2010, 5:11 pm
Anyone ever look into the SKF offerings?
http://www.skf.com/portal/skf/home/indu ... tId=690410
Not sure what kind of $ they ask for yet.
