It is currently April 27, 2024, 9:48 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: December 16, 2011, 2:42 pm
How about a width on the 302 across the top of the heads under the valve cover. Sort of outside corener to outside corner, if that makes sense.
They have an 8.2" deck height. So if you could also get the distance crankshaft centerline to bottom of block, then I could do a compare to the SketchUp model of the LS that I made.
Thanks, I'll post a picture of the two overlaid...
PostPosted: December 16, 2011, 2:56 pm
Cannot get an accurate on the crankshaft as it is still in the truck, but the top of my heads under the valve covers comes to ~45cm.
PostPosted: December 16, 2011, 3:25 pm
I wish we had a nice little pushrod V8 that would do 8000 Rpm or so. 3 liters or less.
There's the Hartley H1 V8, not push-rod or low-cost, but has a smallish footprint, weighs 200 lbs. and revs to 10,000 rpm. :twisted:
http://www.h1v8.com/page/page/1562068.htm
audio clip @ http://www.h1v8.com/f/h1.mpg Nice!
Cheers, Tom
PostPosted: December 16, 2011, 3:47 pm
horizenjob wrote:
Formula cars seem to do ok with upwards of a 1000hp pushing only 500 to 600 kgs.
They work quite well for the 50 or so people in the world that are good enough to deal with it....
Why not spec one out?
PostPosted: December 16, 2011, 4:27 pm
Now THAT'S more like it :)
PostPosted: December 16, 2011, 5:16 pm
http://youtu.be/AACd9YZlh5E this is my favorite clip...shame about the gansta music.
PostPosted: December 16, 2011, 6:35 pm
littlesammy78 wrote:
I am also a fan of the lower RPM V8 sound (not too lopey though!). Nothing like cruising down the highway at 80mph and 3000-3500!
Why would you string it out almost like a 4cyl on the highway? With the torque they put out, highway cruising rpm on a V8 should easily be ~2000rpm, or even a little less. :mrgreen:
PostPosted: December 16, 2011, 7:55 pm
What Justin said. Get a 302 out of a truck so it has the torque cam and a T-5 with tall gears or a 3.73 or lower rear end. If the T-5 comes out of a 4 banger car first gear will be too low.
Tom
PostPosted: December 17, 2011, 5:32 am
I am talking simple physics here not driving ability and anyway there's more than 50 people in the world who can accelerate a car in a straight line..
KB58, there was hundreds of lightweight V8 race cars before wings came along which don't start to work until around 50mph anyway.
Downix wrote:
To add to JD's post, if you want measurements on the 302 let me know, as I have one handy. Solid motor and tons of parts for it.
And a bit lighter than a Chev V8 too.
Sounds good but pretty slow for a 2.5 in a nothing shell.
PostPosted: December 17, 2011, 7:06 pm
I still don't understand why people all across the internet insist on continuing to bring up F1 in discussions about street cars, and even production (and production component) based race cars, seemingly just because they have 4 wheels and an internal combustion engine yet are otherwise completely irrelevant to the subject at hand...In the case of power vs weight vs traction, Formula 1 cars utilize highly advanced electronic control systems that allow them to put all of their power down in the most effective manner possible despite their low weight. One of the comments made by Jeff Gordon when piloting Montoya's F1 car to just 1.3 seconds off Montoya's own times at Indy in only his second session ever out in one of the cars, was how impressed he was with the ability of the technology to allow him to get on the gas without having to worry about traction the way he does in his his NASCAR. Don't forget also that physics dictates the issue of power vs weight vs traction is not just a concern in only straight lines.
Regarding the effects of differential ratios for even a relatively stock Ford 302 + T5 combo powered Locost, or other large torquey engine, assuming a modern street tire size at ~25" tall, I would guess that 3.08 or 3.27 (2300-2500rpm @ 80mph) would be pretty well suited...Taller still would likely even be a possibility considering how much (little) weight the torque is fighting against. This would also probably make the car more tractable in the lower gears as well, with the somewhat reduced torque multiplication.
PostPosted: December 17, 2011, 11:46 pm
Driven5 wrote:
internet insist on continuing to bring up F1 in discussions about .
Who mentioned F1 except you?
PostPosted: December 18, 2011, 2:31 am
Um... you?
cheapracer wrote:
... Formula cars seem to do ok with upwards of a 1000hp pushing only 500 to 600 kgs.
PostPosted: December 18, 2011, 4:33 am
cheapracer wrote:
...there was hundreds of lightweight V8 race cars before wings came along which don't start to work until around 50mph anyway.
Many of which were also balled up into little piles of scrap metal along the way by even some of the best drivers in the world, such that sanctioning bodies have been attempting to limit the increases in power and performance, in addition to improving the crash survivability, ever since...
My apologies for inferring that a Formula car puushing "upwards of 1000hp" would mean F1 specifically...But exactly which other extreme horsepower Formula racing series were you referencing that is any more applicable to this discussion, by not using any type of automated controls to enhance the tractive performance of such a lightweight chassis?
PostPosted: December 18, 2011, 10:24 am
KB58 wrote:
Um... you?
umm no I didn't, actually I was thinking of a large variety of race cars from Can Ams, Sports Sedans through to Indycars throughout racing history - my head isn't stuck up F1's ass as the end to end all of motor racing besides it's rarely been the most powerful series.
No, most didn't crash actually.
How long do you think those controls have been around and specific to F1 as most race series don't allow them?
Anyway, don't know how we got here, a V8 in a Locost is a suitable solution, a number of them out there prove it including members of this forum along with a handful of well known and respected manufacturers - Elfin V8, Caterham V8, Westfield V8, Donkervoort V8, Dax V8, Gillete V8, Stalker V8 (as well as their supercharged V6), others of course and that's just the Locost style without mentioning other lightweight V8 styles and they all seem to be all doing just fine with the concept.
PostPosted: December 18, 2011, 1:49 pm
SeattleTom posted a diagram of a Chevy crate engine with dimensions the other day. Does anyone have dimensioned drawings for a Ford 302? What I have so far is 17.5" width at the outer top of heads, 21" height and 27" ? length. Both this and the Chevy have a lot of room consumed by accessories on the front I think.
I did spend a lot of time looking and reading. If someone could take a few pictures with a ruler that would be a great step. I want to make a version of my frame that would fit these engines. Since much of my project uses roll cage spec tubing and it's designed to be stiff it should be plenty strong enough for V8 based cars.
