My son and I would like to build a low-cost locost. Our goal is to have a car capable of hauling two large adults on the local backroads, I.E. curvy country roads at 50- 70 mph, no racetrack or autocross.
So, we're wondering about starting with the frame/suspension/engine unit from a Ford Crown Vic. The rest of the frame and roll bar would be added to it.
Pros:
Powertrain and suspension is in place and works. We would have much less to fabricate.
Building time could be reduced.
Cost savings. A donor Crown Vic could be had for under $1k and the body sold for scrap.
V8 would provide plenty of power.
Parts are everywhere.
Cons/Concerns:
Handling. It wouldn't be a gocart, but with a fresh, tight suspension would it be good enough?
Engine sits farther forward than a traditional locost.
Long wheelbase. Likely shorten the side frame rails.
Ugly. That v8 is big. Might be able to pull the side frame rails in and build a semi-locost body.
I found pics here
http://www.idmsvcs.com/2vmod/hybrids/ladderframe.html.
What do you think?
