It is currently June 20, 2019, 1:25 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: July 10, 2010, 9:27 am
Linseed oil. It is cheap at $30 or so per gallon at Lowes or Home Depot.
Boiled linseed oil has additives that speed the drying process from weeks to hours.
Do not eat it.
PostPosted: July 11, 2010, 3:28 am
Do not eat it.
NOW you tell me!!
PostPosted: July 11, 2010, 9:22 am
:lol: Yeah, I know nobody would eat it. It probably stinks too. It is supposed to be good for you except for those darn additives. Yum.
PostPosted: July 15, 2010, 11:24 pm
about that foam- anyone know if it might absorb moisture?
you an always get galvanized tube and spray the joints with galva-brite after you weld them :wink:
If you want to fill the frame with something, why not cut holes in the pipes at the joints so you can have flow between them?
Jest another locostusa lurker... for now
PostPosted: July 16, 2010, 9:02 am
Unless you find a foam that specifically states 'water proof' it will soak up moisture and hold it against the tubes, also it's highly flammable, which makes welding tricky.
PostPosted: July 16, 2010, 10:35 am
How can you spray tubes if you're dying from zinc poisoning?
Ford 5.0 into an M3
mikaelvroom.com
PostPosted: July 16, 2010, 9:10 pm
idk we do it every day at work... I would use a respirator (even a disposable would work) if it were me.
Thats what I was thinking- more of a sponge effect.
PostPosted: September 23, 2011, 1:52 am
You could build it out of wood, but then termites would be a problem.
PostPosted: September 23, 2011, 8:25 pm
I would run not walk away from the foam idea. Volkswagen use foam around the rear vents in the late60 to 70 Beetles. Trapped a lot of water turning into a lot of rust. And yes it burns real good when you try to weld a patch panel around it. We have had good results using Eastwood's internal frame spray.
Dave
PostPosted: September 23, 2011, 8:32 pm
You could build it out of wood and then it would be a MORGAN!!! :rofl:
 Post subject: Re:
PostPosted: September 23, 2011, 10:37 pm
violentblue wrote:
drill a 1/8" hole in the solid tube where there is a joint.
it would make the chassis a single chamber, fill it with helium for weight reduction.
But won't it fly if you hit a big bump? Can you use heavy helium to avoid that?
