ooooh ...
How about simply adding a chain drive sprocket to the output of a North-South Drive train to make a light 'transfer case'. There would be space issues of course, but consider the following:
- a conventional front engine BEC Locost with IRS
- a transfer sprocket on the input of the rear diff
- the driveshaft (multi part, or multi-bearing to control whipping) for the front diff would run from the 'transfer case' back up the (now wider) tunnel, to the right of the generally offset bike engine
I suspect the space issues would be unworkable, and what joy in living beside two driveshafts.
OK for a one person sidewinder I guess.
(This is just an off-the-cuff response to the previuous post)
[Next day edit: This is a terrible idea! Unless the transfer box includes a diff there will be all sorts of driveshaft windup with negative effects on tire wear. The same would apply to simply chain-driving a long layshaft (dtriveshaft) directly from a BEC and connecting it to front and rear differentials. It would be like driving a Jeep CJ in 4WD on dry pavement. Makes or terrible skid recovery too!
Warren
Build Log:
viewtopic.php?f=35&t=11601
