nocones wrote:
Yes but you have to admit that this type of car that only turns left on what are realistically very smooth tracks is a bad model to use an example to how to properly design a road going vehicle. Now if you are making a supermod lotus 7 that will run on smooth tracks and only turn left, I'd for sure use those as inspiration..
I'm not saying a lot can't be learned form all classes of racing, nor am I implying that anyone who designs/engineers/works on a successful racing car of any class is in any way inferior to anyone else. I'm just saying that you have to be careful about what you assume translates from the track to the street. I'm not going to use a SCORE truck as a basis for engineering a F1 car, however I may learn something from packaging, or materials on that SCORE truck so it's worth being made aware of.
Turning left only has nothing to do with tyre contact patch for a beam as both sides are flat 99% of the time but ironically and totally against your stance it has everything to do with IFS - you can set up the right and left cambers/caster etc. as they do in NASCAR and INDY to get a very good contact patch for only left handers but if you need to turn right as well then it's back to a compromised setup.
Again and ironic that some of the shitty handling cars around that I see with wheels in all sorts of awkward angles are based on F1/racing designs and that includes here - I'll post a picture when I get home as an example tonight. The amount of cars that are built on track tech/theory around here and everywhere else rather than building for the real world street is ridiculous. Miniturisation of SCORE designs would probably suit more builders here than F1 designs.
You make a point that beams are well developed for speedway but I counter that for IFS as it was well developed because of bad roads 70 years ago and the IFS gave a far superier ride to heavy cast iron beams - since then of course the car has been totally developed and designed around the IFS but even today it's still a compromised mystery/black art how to get one to work properly where as out of the box a beam will offer 95% of it's potential immediately.
And lastly unsprung weight is hugely overated for our needs not that I can't build a beam that isn't lighter than say a standard Toyota suspension package.
