It is currently Wed May 22, 2013 3:32 pm
Post new topic Reply to topic  [ 111 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: The construction of the Lotus 7 in Ukraine
PostPosted: Tue Aug 23, 2011 3:36 pm
Добрый день Всем! Хочу рассказать за постройку Лотус 7 на Украине, город Одесса.
Проект начат в 2010 году.
За несколько лет теоретической подготовки знаю, что хочу увидеть на финише и более менее план набросал.
С рамой сложностей не испытал, имел опыт приличный, работал сварщиком на заводе VOLVO
Надеюсь на интерес к моему проекту и общению
Good day everyone! I want to tell you about the construction of the Lotus 7 in the Ukraine city of Odessa.
The project started in 2010.
A few years theoretical training know that I want to see the finish line and more than a plan sketched out.
With the frame complexity is not experienced, had a decent experience. worked as a welder at the plant.
I hope the interest in my project and communicate .
File comment: Since this all started
http://www.youtube.com/watch?v=rbjV0SHh ... 4DD126786F
 Post subject: Re: The construction of the Lotus 7 in Ukraine
PostPosted: Tue Aug 23, 2011 7:50 pm
Добрый день yourself!
What kind of donor car are you using?
1 down, 2 to go
http://www.locostusa.com/forums/viewtopic.php?f=35&t=12234
http://www.locostusa.com/forums/viewtopic.php?f=35&t=14030
PostPosted: Tue Aug 23, 2011 9:14 pm
Man of Constant Hazard
Добрый день Всем!
Can't wait to see more!
-dave
Visit my [Locost 7 build log]
PostPosted: Tue Aug 23, 2011 10:00 pm
What will you be using for the donor?
Looking good so far!
PostPosted: Tue Aug 23, 2011 10:15 pm
Welcome to the group! Your build looks good so far, keep up the good work, and keep sending us updates! Thanks for sharing your build with us.
PostPosted: Wed Aug 24, 2011 1:00 am
[quote="Odessa"]Добрый день Всем! Хочу рассказать за постройку Лотус 7 на Украине, город Одесса.
(end quote\)
Слухай друже
Ти не будуєш Льотус Севен , на твої картині
це Льокост.
Я маю досвідченя в тім проекті і допоможу
якщо будеш писати державною, а не кацапскою мовою
Евген
Ewhen
PostPosted: Wed Aug 24, 2011 1:03 am
привет хороший автомобиль помощника .. приветствует то, что включает ваш автомобиль? .. man my Russian sucks anyway welcome ..it is looking good so far
what motor and drive train are you going to use ?
PostPosted: Wed Aug 24, 2011 1:14 am
I will keep it simple - :cheers:
I hope your project goes well, we look forward to seeing more.
PostPosted: Wed Aug 24, 2011 7:01 am
Спасибо за горячий приём и интерес. С радостью расскажу всё, что сделал до сегодняшнего дня и покажу на фото.
Я использую новые детали от автомобиля ВАЗ. Донор не покупал, в Украине старые машины дорого и плохие.
Книгу использовал Рон Чампион но делаю немного изменений. Двигатель ВАЗ 2104, 1500 см 3 и оминальная
мощность двигателя при частоте вращения коленчатого вала 5000 об/мин,: 50,0 кВт.- (68,0 л.с.) Мощность небольшая но можно доработать и поднять до 120 л.с. Хочу сделать машину лёгкую для хорошей скорости. Когда строю узнаю много нового, интересного.
Чтоб сделать передние рычаги сделал кондуктор. С заднего моста срезал все крепления и сделаю свои. Задняя панель из алюминия 3 мм. Много сил ушло когда делал панель.
Thank you for your warm welcome and interest. We are pleased to tell you all that he had done to date and show the photo.
I'm using the new parts of the VAZ. Donor did not buy, in Ukraine the old machine is expensive and bad.
Ron Champion book used but make a few changes. Engine VAZ 2104, 1500 cm 3 and a nominal power of the engine at cranking speed 5000 r / min: 50,0 kW .- (68.0 hp) Power a small but can be modified and up to 120 hp I want to make the car easy for a good speed. When the ranks learn many new, interesting.
To make the front levers made ​​jig. On the rear axle cut all the fixtures and make your own. Rear panel made ​​of aluminum of 3 mm. Much effort went when I did the panel.
PostPosted: Wed Aug 24, 2011 7:28 am
Ewhen hello, Я нормально говорю и на украинском и на русском но Одесса город многонациональный и все говорят на русском. Я очень плохо знаю английский язык и поэтому пишу на двух языках, может если не понятен мой английский смогут перевести с оригинала.
Я с удовольствием познакомлюсь и пообщаюсь мой майл viziter2006@yahoo.com
PostPosted: Wed Aug 24, 2011 8:53 am
This will be enjoyable to follow your progress! I also like to read English Russia, the cars that people build there are amazing.
Nice workshop decor!
What kind of welding are you doing?
PostPosted: Wed Aug 24, 2011 10:17 am
Good welding! Nice job on front levers...
PostPosted: Wed Aug 24, 2011 4:59 pm
Nice workshop decor! :D
Это гараж в котором ставлю машину., Для работы сделал стол с колёсами, ставил под стенку и заезжал машиной. Мне нравятся ваши гаражи, много инструмента, станки
Я сейчас работаю водителем и строю мечту вечерами и выходной день.
This is a garage where I put the car., For he made the table with wheels, placed under the wall and dropped in the machine. I like your garage, a lot of tools, machines
I am working on a driver and build a dream on evenings and weekends.
I use carbon dioxide welding. ( correctly understood the question? )
PostPosted: Wed Aug 24, 2011 5:08 pm
Yeah that top picture makes it look like it's being built in his daughter's bedroom, lol.
PostPosted: Wed Aug 24, 2011 5:16 pm
Евген, Це твій локост? Дуже добре виглядає і бачу що потужний двигун. Підкажи будь ласка в чому різниця між лотус і локост.
