Try 5'11", but I make up for it in girth.
I would have liked to remove more from the passenger seat area, but that as far as I could go without cutting through. The rear most section of the base kicks up very high. One could cut the plastic base and add a piece of metal with sheetmetal screws to attach it, then add a foam filler underneath. I didn't think it would be worth the trouble.
I also trimmed the seat base edge so it ends just above the center line of the tubing. See difference in tubing overhang between untrimmed photo and the other side.
It is hard to see in the photo, but I thinned the drivers seat by about an inch also.
I won't be reinstalling the trim rail around the back.
Unfortunately, I don't know which fuel pump they rob the rubber disc from for the overhaul.
Ford IFS
viewtopic.php?f=5&t=13225&p=134742Simple Spring select
viewtopic.php?f=5&t=11815LxWxHt
