It is currently April 17, 2024, 11:44 pm
Post new topic Reply to topic  [ 147 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
PostPosted: January 3, 2012, 6:46 pm
More progress.... framed out the back half of the chassis. Looks like i'm building a nascar truck!
Cant wait for it to be a roller!!
PostPosted: January 16, 2012, 11:14 am
Small update. Still waiting on rear suspension parts to come so I decided to tackle the task of bending square .065 large radius for the body frame work. Do you see any similarities? I'm going to do my best to replicate my favorite Cam-am era car, the Porsche 917/10! ALso mocked up the radiator
Plus i've been working on wing profiles. I'm using a bunch of calculators and it looks like i'm getting 500lbs of downforce with only minimal drag @ 100mph and 1300lbs of DF @150mph! with 100+ lbs of drag. I'm working with an online CNC/laser machine shop to cut all my parts out.
PostPosted: January 19, 2012, 7:39 pm
Rollin... 72" width 110" WB
PostPosted: January 19, 2012, 8:26 pm
Boy that looks strange without a motor or anything. Looks like you need to push your seat back.
PostPosted: January 19, 2012, 9:29 pm
Seat is exactly where it will be, 15 gal fuel cell is going right behind the seat.
PostPosted: January 19, 2012, 10:54 pm
I presumed as much, I was just saying that without all the other stuff it looks odd. I'm sure that once you get the other pieces things will begin to fall into place.
Looking at a traditional Locost at that same stage it has some strange looks too.
PostPosted: January 20, 2012, 7:32 am
I agree... once we get the V8 back there with F1 style exhaust coming up out of the top it will look beautiful :D
PostPosted: January 20, 2012, 11:19 am
That would make even an ugly girl look beautiful.
PostPosted: January 20, 2012, 7:30 pm
Am I safe to assume that the motor will be mounted with plates on the bellhousing and front of the engine? It would stiffen the rear of the car and make the engine a "semi" stressed part of the chassis. Engine plates are readily available for the bellhousing area from many circle track suppliers but you may have to make one for the front as I am not sure what the pattern is on these motors.
PostPosted: January 21, 2012, 12:54 am
There are several people who offer front/mid plates for the LSx engine.
http://www.competitionengineering.com/c ... Code=11073
http://www.burkhartchassis.com/id88.html
http://www.madmanandcoracing.com/
I understand that Stenod Performance and Fab-Jet Services may also be potential suppliers. There may be other quality plate suppliers as well.
Cheers, Tom
PostPosted: January 21, 2012, 8:40 am
Thanks guys! I found a bunch online. Only issue is I dont weld aluminum so I'd need to find a smaller steel one that I could costom fab with. Getting one cut out for me might be an option.
PostPosted: January 21, 2012, 10:57 am
Framed out the front clam.
PostPosted: January 21, 2012, 4:14 pm
Aluminum welding not required to use the aluminum engine plates. Just weld several steel tabs to your frame at the appropriate places and trim the aluminum front-plate and mid-plate outer ends to mate with those tabs. Drill the plate and the tabs and bolt the driveline up.
The mounting tabs could also be incorporated into bracing added to the engine bay sides for additional strength.
Cheers, Tom
PostPosted: January 22, 2012, 1:37 pm
So the front mount plate mounts where on the block? Between the bell and block? Or the front of the block? And where would you guys suggest I tie the plate into? The main roll hoop + the middle section of the chassis floor?
Thanks!
PostPosted: January 22, 2012, 3:51 pm
The front plate goes between the block and the waterpump, the mid-plate between the block and the bellhousing. See pics below. The first pic shows both front and mid plates mounted to a tubular (front engine) chassis without the engine in place. The second one shows a front plate fixed to an LS engine without the water pump mounted. They should give you some idea of how it all goes together.
One approach to fitting engine plates to your chassis would be to bolt up the block and transaxle, including the front and mid plates, locate this in the chassis where you want it relative to your rear axle line. Then position and weld steel tabs to the chassis, drill the plates/tabs and bolt the driveline in place. You might also consider adding verticle tubes to the chassis engine bay for greater strength and attaching the tabs (or flanges) to these instead. You could also triangulate these verticles along the sides for added chassis stiffness.
Cheers, Tom
