You've narrowed it down to a small domestic (versus a rebadged import).
A 1986 escort with power brakes has a 19.75mm bore which is .777". The manual version is 21mm if you find your running out of pedal travel.
It has a separate plastic resevoir but it may not be aluminum.
You might try increasing the pedal ratio to use a larger bore with similar effort and travel.
Ford IFS
viewtopic.php?f=5&t=13225&p=134742Simple Spring select
viewtopic.php?f=5&t=11815LxWxHt
