No auction number / url?
http://cgi.ebay.com/ebaymotors/Replica- ... 2321694b15This car is in excellent running condition and is VERY fun to drive.
Current Arkansas clear title.
Bottom frame rail is 16 ga 1 x 2 rectangle.
Steel floor pan.
Caterham fiberglass body kit
Front Spindles from a Pontiac Fiero.
Engine is a rebuilt Toyota 3TC
Transmission from Toyota Corolla
Master cylinder from a Corvette
Front & Rear disc brakes.
Front coilovers.
Rear pro coilovers.
Rack and pinion steering.
Weber carb. (new)
Fuel tank 14 gallon.
4 point Seat belt harnasses.
Battery shutoff switch.
2 ignition keys.
Cigarette lighter/power outlet
Brakes are strong, clutch is good, shifting is tight, steering is solid, tires are excellent. There is some pitting and rubbing on the paint/body since this car has been used as an occasional driver and has picked up some rocks here and there. I've provided closeups of anything slightly apparent so you can see for yourself. You're welcome to come visit for a test drive before bidding if you'd like.
