It is currently July 11, 2020, 11:03 am
 Post subject: bending dies
PostPosted: March 1, 2013, 2:08 pm
well, i finally saved up enough money to buy a tube bender so i decided on the jmr bender with the 1" and 1 1/2" dies. it seems to be a very quality and heavy duty bender. i assembled it and realized that i received 90 degree dies because i forgot to specify that i wanted the 180 degree ones :BH: .
if i build a cage for my locost i know i wont have to bend over 90 but i have always liked the little "hoop" bars that are on the cobras. i would also like to build brush guards, dune buggies and maybe a formula ford or two with the bender after the locost is done. will i ever need the 180 dies for projects like these, or will i be fine with what i have?
i have heard of people re positioning the tube in the 90 degree dies after the first bend to create bends with a steeper angle. will that be good enough? im sure it will take a little practice to get correct.
 Post subject: Re: bending dies
PostPosted: March 1, 2013, 2:19 pm
It takes practice and I do 3 sets of 60 degrees - you need to do the outside 2 first then the middle one last.
If you try to do a 90 then another 90 your tube will most likely hit the side of the machine thats why the 3 bends.
Do a sample bend and find out the distance from the bends edges to the middle of the bend and work it out from there where to put your 3 chalk marks.
PostPosted: March 1, 2013, 2:30 pm
thanks cheapracer for the advice. im glad i wont have to exchange them now.
PostPosted: March 9, 2013, 10:57 am
Cheapracer, when you make the 3rd bend doesn't that mean that the U-shaped strap is positioned over an already bent portion?
Users browsing this forum: TooBusy and 1 guest
