July 10-17 / 20012
Closed up firewall and finished all undercoating / Finished exhaust engine to diff / trimmed pass side steering rack for boot fitment issue / Final install of brake lines, adjustable proportioning valve, line lock, and master cylinder / Finished interior floor w/ POR15 and 2 coats of Henry's Roof Sealant (added microspheres) / covered floor with Peel n Seal- 2 layers at firewall and front floorpan and 1 layer under front seats and rear of car / fabbed seatbelt mounts (front only).. / modded all 3 OEM N600 pedals as needed to work with new/ altered geometry / finished paddle shifter cable 'spider' bracket at engine (this took 3 attempts to get the correct angle for the cable.. / fabbed paddle shifter at column / cleaned front and rear window flanges and painted w/ POR15..
July 18-21, 2012
Went back ant had to cut slots into firewall where clutch and throttle cable go through so a cable can be changed/serviced later.. / painted all small enine mount bits / finished clutch linkage arm / Fitted pedals for install height.. For grins swapped motor #2's instrument cluster into the VFR... very surprised to learn this motor only has 17,000 miles on it!!
I knew it was clean from having it opened, but I had no idea it would only have 1/3 the miles of my bike... hoping it runs well- if so, it is definately the 1st choice motor to use for this car.. / sealed up engine #2 (had the covers off of both sides) and preparing it for 'final' install to run it (I've had it in and out of the car at least a dozen times for fitment)..
7-20/21, 2012
Stripped VFR completely.. I didn't want to do this (as motor #2 looks so good), but I needed the bike's harness, starter, and some other odds and ends... Once it's all parted out I will have all that my N600 project needs, and although selling/shipping stuff is a hassle, I'll eventually get all $$ back that I spent on the VFR originally..
7-21-2012
Installed motor #2 for final time.. Installed driveline.. Finished fabbing clutch linkage..
Dean
1963 Volvo P1800 Restomod
http://locostusa.com/forums/viewtopic.php?f=36&t=163091959 Berkeley SE492 Restomod...
viewtopic.php?f=36&t=19397"ccrunner's 1960 MGA coupe Restomod" found on MGExp.com
