It is currently March 24, 2019, 9:16 am
Forum rules
 Post subject: Lotus S3 clone
PostPosted: November 29, 2013, 1:27 pm
I have visited this board off and on for a while and would like to share my completed build of a lotus 7 Series 3 replica. I have never seen a S3 in person, but photoshop is quite usefull to figure out dimensions and proportions. After 3+ years of self imposing a no sports car rule to keep the drive to finish the 7 I now have a car that puts a bigger smile on my face than any other car I have owned. In any case on to the good stuff:
Frame: Mixture of 1" square, 3/4" sqaure, and .09" 5052 Al floor pans/firewalls. The firewalls and transmission tunnel are sikaflex and SS riveted to the frame. The result is very stiff and seems very well behaved on the road. An IRS system was also squeezed into the package.
Running Gear:
A 94 miata donor was used for the majority of the parts.
Torsen LSD diff
1.8l miata motor
5 spd tranny
QA-1 coilovers with adjustable dampeners.
Summit springs.
miata hubs and brakes
Tilton dual master pedal assembly
civic radiator and catch can
modified miata axles
modified/depowered miata steering rack
Caterham rear fenders and nose
Koso gauge cluster
Kirkey 15.5" drag seats with 5 point harness. Driver seat is on an adjustable slide.
10 gallon custom fuel cell.
Wheel Base : 87.5"
Track F/R: 54" 53.5"
Weight: 1290lb wet
Overall Driving impressions over the last 300 miles: The car tracks well with a surprisingly smooth ride for such a short wheelbase. I spent a little time with the dampener settings and have the balance pretty neutral with a little understeer when pushed that transitions to a controlled oversteer nicely.
More detail pictures to come.
Next upgrades:
Tires: The current ones are pretty worn and generic all weathers. Makes driving on the street fun!
MORE POWER!!! planning on putting a TD04 turbo with a wrx intercooler.
Doors - Durng nice weather doors are not needed. However, in the cool mornings and on mountain roads, doors will be a nice to have item and keep the wife happier.
 Post subject: Re: Lotus S7 clone
PostPosted: November 29, 2013, 2:51 pm
Beautiful. But that's not nearly enough details for us. Do you have a build log posted anywhere? BTW, very hearty congratulations, that's a huge accomplishment.
PostPosted: November 29, 2013, 3:01 pm
Very nicely done. Please put up some more pics of the car.
PostPosted: November 29, 2013, 11:51 pm
That is dimensionally gorgeous.
Did you make the scuttle?
Did you use a set of existing plans, or make your own out of your head?
More detailed pictures please, especially of the build.
The Lethal Locost
PostPosted: November 29, 2013, 11:57 pm
What Skinny said......
PostPosted: November 30, 2013, 12:05 am
Great looking car and more build pics please. :cheers:
PostPosted: November 30, 2013, 12:07 am
^ Agreed with SkinnyG and dfdahl. We need more photos and details. :D
You have a very nice seven there. very well done!
PostPosted: November 30, 2013, 9:50 am
Thanks guys! The frame design is a conglomerate of other's ideas and solutions. The dimensions were estimated using photo shop and taking time in CAD to get it to look aesthetically pleasing as possible.
The scuttle was formed by first using a brake to put in the offset where the hood sits. A local shop has an edge hem tool to put a finish on the cockpit side. A plywood form was made to bend and secure the scuttle into final shape and the edge that forms around the firewall was beat into place. I'll post pictures when I get a chance.
PostPosted: November 30, 2013, 9:53 am
A great looking Seven!! Looks the size of the orginial seven with the downward slope on rear boot plus the shaper rear kick up and a shorter cocpit. Definitely a SUPER Seven. :cheers: Dave W
 Post subject: Re: Lotus 7 S3 clone
PostPosted: December 1, 2013, 11:16 pm
tbd
